replacing bathroom floor with ply plus other queries
warmadmax
Has thanked: 13 times
Been thanked: 74 times
Re: replacing bathroom floor with ply plus other queries
Post by warmadmax »
piccies a deffinate, even if i cock it up :lol: :lol:
quick question,
how easy / do-able is it do two different coloured grouts on a wall, say grey or black for the lower half black tiles and white for the upper half (white tiles)?
is there any technique for doing this? or will it look shocking and i should stick to one colour?
DTWCeramics
Been thanked: 43 times
Post by DTWCeramics »
don't, it'll look ghastly.
stick with white the whole way through :) It gives a great contrast to the black tiles and compliments the white tiles brilliantly.
Only time to use black grout really is black/charcoal floor tiles (or white octagon tiles, looks quite nice!)
Cheers :thumbleft:
Matt
Colour Republic
Has thanked: 263 times
Been thanked: 544 times
Post by Colour Republic »
Sorry DTW I disagree with the right design and the right tiles it looks fantastic
DTWCeramics
I'm always up for something different!
Have you got any examples CR?
Only time I've seen it look half decent was black on white but that was in a feature area.
will happily shush my mouth if I like something, and I do like quite funky designs!!
Cheers :thumbleft:
Matt
warmadmax
Post by warmadmax »
hi guys, attacking the window cill now,
any idea what these are?
2012-10-13 12.56.56-50per.jpg (332.63 KiB) Viewed 2038 times
2012-10-13 12.56.48-50per.jpg (486.87 KiB) Viewed 2038 times
2012-10-13 12.56.43-50per.jpg (411.97 KiB) Viewed 2038 times
ayjay
Has thanked: 458 times
Been thanked: 1708 times
Post by ayjay »
Quarry tiles.
warmadmax
Post by warmadmax »
thought they were when i saw them initially but didn't expect them to be that thick!
if it remove them all, does it look like the cill will be strong enough to tile onto?
the outer two are set a couple of inch into the wall unless they've been cut.. (here's hoping!)
DTWCeramics
They're just round edge quarries Matt, although they're bloody thick :shock:
They look like they've been on there for years, the substrate looks sound from pictures, if in doubt slap a bit of plaster on it and level it first?
Should look nice! Assuming the white tiles will be used for these?
Matt
warmadmax
Post by warmadmax »
was going to run the mosaic border a tile higher and have black as the cill,
think a white tile cill would look odd it being surrounded by black tiles :lol:
aye think a coat of plaster after i've removed them would be a sound idea :thumbright:
warmadmax
Post by warmadmax »
damn the blighters are set into the wall, looks like they actually laid the brick course over them :? :wtf:
rounded edge stands 8mm proud of the plaster finish so gotta get them cut back or suffer the plastic cill again... ::b
I brought a evolution mitre sawthat i've had my eye on waiting for it to come back on offer @ SF.
doing the noggings in double quick time with that, also got a diamond blade for it while its on offer.
i've got the 5 middle ones loose, i can probably cut the rounded edge off these with the mitre + diamond blade if i take it steady and clamp them down,
then it's just a job of hacking the two outer ones that are set in the wall,
dont think a hand tile cutter will touch them some how as a chisel + hammer wasn't having much affect :lol:
think i'll try the SDS + chisel on it tomorrow :scratch:, i'll try and cut a break line in it first with a carbide blade, or if the SDS absolutely mashes them, i'll break them up flush with the plaster
Cheers Guys
DTWCeramics
SDS should mess them up quite well :D
Odd to see a sill being built around, guess it worked though!
good luck getting it off of the window sill
Cheers :thumbleft: :thumbleft:
Matt
warmadmax
Post by warmadmax »
these....
2012-10-17 23.22.54.jpg (92.75 KiB) Viewed 1958 times
2012-10-17 23.22.45.jpg (111.9 KiB) Viewed 1958 times
plus this and the SDS + Chisel...
2012-10-18 19.42.55.jpg (140.27 KiB) Viewed 1958 times
equals
2012-10-18 19.42.43.jpg (184.08 KiB) Viewed 1958 times
2012-10-18 19.46.04.jpg (85.11 KiB) Viewed 1958 times
2012-10-18 19.45.55.jpg (98.78 KiB) Viewed 1958 times
2012-10-18 19.45.49.jpg (88.18 KiB) Viewed 1958 times
2012-10-18 19.46.15.jpg (38.68 KiB) Viewed 1958 times
and a little helpers investigating :D
2012-10-18 19.43.26.jpg (143.87 KiB) Viewed 1958 times
DTWCeramics
Nice neat job there Matt :)
Well done on being able to count to 5 btw :cheers:
:wink:
Matt
warmadmax
Post by warmadmax »
cheers :-) they did have old adhesive on the edges so thought number em up and put em back in same order,
sods law, to get em square in the mitre i ended up chipping it off so didn't really matter :lol:
they're laid in loose apart from the edge ones so will set those back in properly and level after i've cleaned the paint off them :thumbright:
edge tiles i took the oscilliating tool + carbide blade to cut a shallow score line in it and to give the chisel something to sit in,
took a while to chip away at them even with SDS, soon as they were through there was only plaster underneath to stop it... and it didn't stop it :lol:
hopefully plasterer will turn up tonight to fill chases and the mess under the other tiles from the sds :-)
should have the floor done this weekend, then i can get bath back in properly + line up the sink and fit temporarily.
warmadmax
Post by warmadmax »
well this is taking longer than expected :lol:
resited the towel radiator, redone the pipes,
then managed to slip when i was notching this nogging...
whoops
whoops
2012-11-03 23.06.51.jpg (218.11 KiB) Viewed 1782 times
new skylight for downstairs toilet :lol: another job :roll:
well after that, had to get the boards down.
1
1
2012-11-11 19.52.45.jpg (170.55 KiB) Viewed 1782 times
2
2
2012-11-11 19.52.56.jpg (188.77 KiB) Viewed 1782 times
3
3
2012-11-12 21.49.10.jpg (159.53 KiB) Viewed 1782 times
small sheet to screw down, it got wet as i was cutting on the decking so let it dry overnight.
once thats done, off cut of ply under bath feet, redo batterns accounting for floor + tile height,
refit bath (she's been suggesting :lol: ), remove paint off walls... :shock:
Return to “Tiling Forum”
