Lidl Tools Monday 29th June
- Puma
- Has thanked: 681 times
- Been thanked: 709 times
Re: Lidl Tools Monday 29th June
I use an Ebauer one - I think it was about £60 new. Needs regular greasing, as I guess they all do. The chuck is okay. I have a lighter version of this one from Lidl - all seems okay, it has been used for mixing about 30 tubs of different plasters and a couple of hundred holes. The hammer action seems to be a bit harder to get going - but I haven't lubricated it yet.
- These users thanked the author Puma for the post:
- London mike 61
- Has thanked: 893 times
- Been thanked: 729 times
I bought the ratchet & bit set, the angle finder & calipers. All fairly good quality for my needs & I got a fiver off for spending over 25 quid with their discount card, that the wee lassie at the check-out gave me.......well chuffed
Time-served Plumber/Heating Engineer & general wind-up merchant.
The Plumbers Anthem
If you have found my help or tips useful please donate here. Thank You;
Gas Safe RGI
Scottish, British & Proud.
I'm not or never claimed to be Chris Williams.
The Plumbers Anthem
Gas Safe RGI
- Has thanked: 285 times
- Been thanked: 403 times
I bought the Sds drill, haven't used it yet but we are about to move house in the next month and it wil be used a fair bit then.
After reading some stories about the bit getting stuck in the chuck, I read a tip that if you put a smear of Vaseline on the bit when you push it in then it makes it easier to take out. I don't know if it is true but I reckon that if you don't put some kind of lubricant on the thing then you are asking for trouble.
Still the drill looks good enough for what I want and when I get to use it I will give feedback to the forum. The next thing is where to buy a good quality range of drills for general use?
Mike
Mike
- wine~o
- Has thanked: 1415 times
- Been thanked: 4024 times
Mike vaseline has it's uses buuuut http://www.screwfix.com/p/makita-p-0836 ... stid=39857
Is the proper stuff.
- These users thanked the author wine~o for the post:
- London mike 61
wine~o wrote:Mike vaseline has it's uses buuuut http://www.screwfix.com/p/makita-p-0836 ... stid=39857
Thanks wine-o, I'll get myself some of that!
- Has thanked: 109 times
- Been thanked: 1038 times
I just use a bit of axle grease, I have a half gallon tin of the stuff.
Rorschach wrote:I just use a bit of axle grease, I have a half gallon tin of the stuff.
That should last a while !!
London mike 61 wrote:Rorschach wrote:I just use a bit of axle grease, I have a half gallon tin of the stuff.
Well I have had it for a few years now and you can just about tell I have used some
The main thing I use it for is to lube my lathe chucks, most other things in the shop require oil rather than grease.
Rorschach wrote:London mike 61 wrote:Rorschach wrote:I just use a bit of axle grease, I have a half gallon tin of the stuff.
The trouble for me will come when we unpack all our stuff in our new house and then I ask ; now which box did I pack that little bottle of grease that I bought?.........
- Puma
I would have thought any grease would do - a bit alarmed by just buying that tiny quantity for such a lot of money. The Ebauer one has a grease port and you have to use 100ml per refil.
The lidl one does not have a port to fill up with grease, it is only to help insertion and removal of the bits.
But I do wonder what the data sheet ( coshh ) says as to regards viscosity and temperature performance for the Makita lube. It is probably the right stuff for filling a dedicated port, but to lube the bit ( just a smear ) any grease should do I would think.
Mike
Mike
Yeah great tip Mike, last time I did that look what happened - he'll be 25 next Birthday!!!.....London mike 61 wrote:I bought the Sds drill, haven't used it yet but we are about to move house in the next month and it wil be used a fair bit then.
After reading some stories about the bit getting stuck in the chuck, I read a tip that if you put a smear of Vaseline on your bits......
Mike
- These users thanked the author Dickie for the post (total 2):
- Puma • London mike 61
- Rating: 14.29%
The Plumbers Anthem
Gas Safe RGI
The Plumbers Anthem
Gas Safe RGI
- Timllfixit
- Has thanked: 146 times
- Been thanked: 209 times
I bought one of those Lidl SDS+ drills when the local Bath store had them for £14.99!! (Well I'd have been daft not to wouldn't I!. AND it came with two chisels,three SDS drills, SDS chuck adaptor and 3 year warranty! I would have bought more and sold them on E-bay but it was the last one.
http://www.lidl.co.uk/en/our-offers-249 ... l&id=26087
I have used it a couple of times now for chiseling away concrete for a fence project and it's AWSOME! It seems fairly robust, but how it will perform in the future remains to be seen. It'll probably be OK for anything I want it for, and is allready worth what I paid for it. Probably a bit OTT for chasing out but as a medium DEMO hammer probably fine.
- Has thanked: 37 times
- Been thanked: 15 times
a lot of the tools on their specials arent hugely value for money often an equivalent can be purchased from screwfix, or less. http://www.screwfix.com/p/energer-enb46 ... kpid=63303Timllfixit wrote:I bought one of those Lidl SDS+ drills when the local Bath store had them for £14.99!! (Well I'd have been daft not to wouldn't I!. AND it came with two chisels,three SDS drills, SDS chuck adaptor and 3 year warranty! I would have bought more and sold them on E-bay but it was the last one.
Ha, ha! Love itDickie wrote:Yeah great tip Mike, last time I did that look what happened - he'll be 25 next Birthday!!!.....London mike 61 wrote:I bought the Sds drill, haven't used it yet but we are about to move house in the next month and it wil be used a fair bit then.
Mike
