Intergas 24/18 HRE compact Combi
Mehran2
Has thanked: 6 times
Been thanked: 39 times
Re: Intergas 24/18 HRE compact Combi
Post by Mehran2 »
sounds good,
Is the flue the 'rhino' type with the up turned nose? and did you get kit A in the end?
a good idea at this stage is to see if the little PRV stub and nut can be unscrew. I have found some that are rock hard to unscrew and almost have to take the boiler off the wall to unscrew them. I think they pre-wet the washer or something? by the time it gets to you it has dried and stuck solid.
thescruff
Has thanked: 360 times
Been thanked: 3735 times
Post by thescruff »
Yes Mehran, it has a funny bit of tube turned up, :thumbright:
thescruff
Post by thescruff »
Here we go then.
Draining the system and cylinder out 8:00.
Got till 4:00 to get the new boiler in and working, :roll:
Intergas, be warned it had better work :lol:
Razor
Has thanked: 483 times
Been thanked: 1251 times
Post by Razor »
Silly biatch forgot to post it!!! But it went Saturday Scruff :thumbright:
Theres nothing stopping you fitting Plumbcenters one and taking the other one back when it arrives is there? :wink:
thescruff
Post by thescruff »
Old stuffs out, new boiler on the wall and the flow and return connected. :thumbright:
Razor
Post by Razor »
thescruff wrote:Old stuffs out, new boiler on the wall and the flow and return connected. :thumbright:
Managed to connect up to the old lead then :lol:
thescruff
Post by thescruff »
No Sweat, :lol:
Hots connected, just the mains and gas to go. :mrgreen:
Who forgot the filler loop then :scratch:
D Hailsham
Has thanked: 29 times
Been thanked: 149 times
Post by D Hailsham »
Wot, no eight hour powerflush???!!
Mehran2
Post by Mehran2 »
so good so far I hope :-P
what I like to do is put a full bore valve as a drain on both the flow and return under the boiler. so you fill from one side and drain through the other then swap.
thescruff
Post by thescruff »
Water comes out the taps. :lol:
thescruffs boiler.jpg (179.11 KiB) Viewed 4060 times
Razor
Post by Razor »
Didn't they send all the bits for inside the boiler?
Guess you're adding all the pipeclips aftewards :lol:
Mehran2
Post by Mehran2 »
looking good :thumbleft:
remember it only a 9l/m boiler so make sure the flow rate is not too high
thescruff
Post by thescruff »
just hit a problem :roll:
Have a mini flood in the office at the moment, you didn't tell me I had to cap the cold feed and vent. ::b
Mehran2
Post by Mehran2 »
:lol:
btw I forgot to say to watch for loose nuts inside the boiler. what sometimes can happen is when you tighten the valve under the boiler it can loosen the one above inside the boiler.
if you do get any water in the boiler, intergas have kindly proved a sump under the boiler on the right hand side under the pump. there is a little plastic cap to drain any water away.
not to worry john, we all have forgetful moments :wink:
Razor
Post by Razor »
thescruff wrote:just hit a problem :roll:
That's the funniest thing I've heard for ages :lol: :lol: :lol:
But only 'cos I've done it myself :oops: :roll:
It's not to late to get BG in you know :huray:
And it's a senior moment Mehran :wink:
Locked
