More studwork etc
Wes
Wood Flooring Installer
Has thanked: 379 times
Been thanked: 565 times
Re: More studwork etc
Post by Wes »
Tom wrote:Yes I got a reason.. I'm sayin a nice house with a nice car and van outside and a diary booked up for 2years. I that's not because I charge to much!! Majority of my work is for developers all of these company's are either owned or run by ex carpenters/joiners they like me because I do the job correctly and go that extra mile to deliver a better more solid job.
Not wanting to get involved with the hand bags and all that, but I have to say, that's not a reason. That's a boast :scratch: :lol:
Also in all fairness to Tom, I don't understand why he should give a reason when you haven't for 600 c Stevie?? Markings on plyboard surely isn't admisable in court :B
wine~o
Has thanked: 1414 times
Been thanked: 4015 times
Post by wine~o »
thescruff wrote:400 goes into 1200 and 2400 which is what the sheet happen to be,
:hello2: So does 600, 300, 200, 150, 100, 50, 25, I could go on........
MSX
Has thanked: 1 time
Been thanked: 4 times
Post by MSX »
lol. the new builds I've worked on in the past and work on at the moment, the spec is 600. The plans for the houses also say that they should receive 3mm of skim but the site agent has the walls taped and jointed instead to save money since he reckons he's getting an NHBC award :lol:
Wes
Post by Wes »
Now you've just really kicked it off MSX :lol: :lol: :lol: :lol:
thescruff
Has thanked: 360 times
Been thanked: 3735 times
Post by thescruff »
Maybe, but 400mm is the imperial 16in when the boards were 8x 4ft
182michael
Has thanked: 28 times
Been thanked: 69 times
Post by 182michael »
A lot of hate in here for 600 centres lol. Today I fitted 3x2 cls frames at 600 centres with staggered 12mm soundbloc either side, solid enough.
It's purely the preference of the joiner or if it's been specced. Very rarely see 400 centres up here. 38mm trusses at 600 centres with 15mm pb on the underside no problems. JJI joists at 600 centres, again no problems.
thescruff
Post by thescruff »
How about 1st floor joists, are they 600 centers as well.
182michael
MSX wrote:lol. the new builds I've worked on in the past and work on at the moment, the spec is 600. The plans for the houses also say that they should receive 3mm of skim but the site agent has the walls taped and jointed instead to save money since he reckons he's getting an NHBC award :lol:
Skimming new builds lol i've never seen that once. All taped.
Site agents and the NHBC, what a shower the latter bunch are. We get fined at pre plaster if screws are to close on our planking or we don't have 16 nails in a panel joint. Nonsense!
Floor joists are at 600 centres yes.
steviejoiner74
Has thanked: 747 times
Been thanked: 1616 times
Post by steviejoiner74 »
Wes 600 is ample,nearly every roof I've done in over 20 years is set at 600,the timber frame industry uses 600 centres for structural wall panels. Yeah I've set out at 400 when structure requires it or it's picking up heavier thAn normal load from above. On a non load bearing partition,400 is not needed when you factor in the dwangs(noggins). The plasterboard doesn't become any stronger when it's screwed on at 400 centres,or does it :dunno:
wine~o
Post by wine~o »
Can't argue..My old Stanley measure has a "Dot" every 16 inches............ :thumbleft:
Tomwardframer
Wes
Post by Wes »
steviejoiner74 wrote:Wes 600 is ample,nearly every roof I've done in over 20 years is set at 600,the timber frame industry uses 600 centres for structural wall panels. Yeah I've set out at 400 when structure requires it or it's picking up heavier thAn normal load from above. On a non load bearing partition,400 is not needed when you factor in the dwangs(noggins). The plasterboard doesn't become any stronger when it's screwed on at 400 centres,or does it :dunno:
I'll file that under exhibit B...
I'm not sure how it'll fair against exhibit A...A nice house two motors and a full diary for 2 years...
I'll have to get my team of lawyers on this so they can rip it to pieces...In fact! I'm going to give Rumpole a call right now god damn it!! :lol:
These users thanked the author Wes for the post:
steviejoiner74
Steviethejoiner
Been thanked: 23 times
Post by Steviethejoiner »
Tomwardframer wrote:
steviejoiner74 wrote:I think a lot of you guys doon sooth do 400 centres to accommodate running wall sheets horizontal which I find strange as well. Anybody got a proper reason for 400 centres over 600 yet :dunno:
Ok Pinocchio.
ayjay
Has thanked: 458 times
Been thanked: 1708 times
Post by ayjay »
steviejoiner74 wrote:nearly every roof I've done in over 20 years is set at 600,
I guess you're talking trusses here?
I've never cut a roof and fixed the rafters @ 600 centres, it's always 400.
steviejoiner74
Even cut roofs ayjay,always 600 centres. Although every roof I do is either sarking boarded or osb covered as well.
fin
Has thanked: 32 times
Been thanked: 805 times
Post by fin »
cut roofs 400's, on the house we live in me and my mate did the upstairs stud walls at 600's coz we were running outa timber. we were insulating the walls as you do and we were using the 8x4 boards. the insulation was a right pain as it kept falling out from between the studs.
do it on 400 c's or 16 in c's and that dont happen. (16 in c's with handi boards)
all tape measures have the dots for 16 in c's dont they? all the ones i have do anyways
the plans i work to always say 400 c's on the spec lists.
and ermmmm ayjay i think it was... yea thats what i meant. stagered or straight. theres another way in joinering books but ive never done it that way. sometimes staggered sometimes straight. depends what i fancy doin at the time i guess.
These users thanked the author fin for the post:
Tomwardframer
Return to “Show Case Gallery”
