DIY loft conversion
Mark G
Has thanked: 2 times
Been thanked: 8 times
Re: DIY loft conversion
Post by Mark G »
Good job!
These users thanked the author Mark G for the post:
leewallbank
Georgi Yanakiev
Post by Georgi Yanakiev »
Great work!
leewallbank
Has thanked: 8 times
Been thanked: 5 times
Post by leewallbank »
Well embarrassingly it's taken almost 4 months for an update! I've been crazily busy in work, the weather's been crap so I haven't been able to fit the last 2 velux in the bedroom and I stopped working in the attic a few weeks before Christmas so I could finish and redecorate the dining room ready for Christmas dinner!! Excuses over....please see below
not many pictures but fitted the waste in the bathroom before SLC
IMG_2103 (Custom).JPG (89.32 KiB) Viewed 3985 times
after fitting the shower tray and underfloor heating and insulation
IMG_2120 (Custom).JPG (155.28 KiB) Viewed 3985 times
IMG_2123 (Custom).JPG (154.14 KiB) Viewed 3985 times
SLC
IMG_2124 (Custom).JPG (98.73 KiB) Viewed 3985 times
As the ceiling is quite low in the bathroom I couldn't fit a normal light so i opted for LED spots. The only problem was trying to make sure vapour control layer was right whilst ensuring there'd be enough room around the lights so they didn't over heat. I came up with this idea as i couldn't see anything for sale that would work...I'm not quite sure if this will be any good but it was the only way I could think of making sure it was tight. The top of the 'boxes' are 50mm celotex.
IMG_2122 (Custom).JPG (127.87 KiB) Viewed 3985 times
IMG_2115 (Custom).JPG (84.72 KiB) Viewed 3985 times
IMG_2121 (Custom).JPG (119.32 KiB) Viewed 3985 times
IMG_2143 (Custom).JPG (103.93 KiB) Viewed 3985 times
I cut the polythene around the outside of the boxes and used foil tape to shut the edges.
IMG_2144 (Custom).JPG (114.55 KiB) Viewed 3985 times
IMG_2151 (Custom).JPG (127.1 KiB) Viewed 3985 times
IMG_2152 (Custom).JPG (112.79 KiB) Viewed 3985 times
just finishing the pipework so I can plasterboard now
IMG_2153 (Custom).JPG (114.28 KiB) Viewed 3985 times
and finally, weather was pretty good last weekend so fitted the last 2 velux
IMG_2126 (Custom).JPG (134.82 KiB) Viewed 3985 times
IMG_2150 (Custom).JPG (132.02 KiB) Viewed 3985 times
getthewheelsinline
Has thanked: 224 times
Been thanked: 182 times
Post by getthewheelsinline »
Coming on now...starting to take shape! [emoji106]
leewallbank
getthewheelsinline wrote:Coming on now...starting to take shape! [emoji106]
yeah, thanks. The bedroom and bathroom just need boarding now and then obviously the finishing bits. Only thing after that is to connect all of the waste/water/central heating. The multi foil gets a lot of stick but to be fair we've had a pretty miserable winter and its been rather warm upstairs considering there are no rads plumbed in yet.
steviejoiner74
Has thanked: 747 times
Been thanked: 1616 times
Post by steviejoiner74 »
I see you've stuffed glass wool inbetween the rafters and put some thin visqueen over.
Where is the airflow coming from? Maybe I'm misinterpreting the photos but that looks like a recipie for disaster,you need airflow behind the insulation on the cold side or you're going to get serious mould and damp.
leewallbank
steviejoiner74 wrote:I see you've stuffed glass wool inbetween the rafters and put some thin visqueen over.
I didn't show it on the dormer build but the whole outside has celotex fitted - the roof is kind of like a warm deck, plus the polythene should stop any moist air getting to it.
steviejoiner74
Just out of curiosity what is the makeup of the dormers(insulation/air gap etc. And what is directly above the glass wool insulation? I've never seen a detail like that before(I've seen similar and it was saturated and mouldy within a few years)
How are the Combe ceilings insulated? Fo you have a minimum 50mm airflow between the insulation and the outside roof at those points?
leewallbank
from the outside in on the cheeks: render board, 25mm batton, membrane, 50mm celotex, 12mm ply. roof: fibreglass, 11mm osb, celotex, 12mm ply. the 'original' roof has superquilt with 50mm air gap left between the felt and quilt. ventilated soffits and ridge too, as well as 3ft of open space within the eaves.
DmitriKara
Has thanked: 58 times
Been thanked: 18 times
Post by DmitriKara »
looks great mate! I bet it will turn out as good as it looks. would be fun to see a photo when done
These users thanked the author DmitriKara for the post:
leewallbank
M1ke_a
Has thanked: 45 times
Been thanked: 29 times
Post by M1ke_a »
Wow, champion job and looks like a cracking location :thumbright:
With the celotexed light boxes were you just going to attach the fittings to the inner plasterboard?
DmitriKara
Looks better and better! Bravos
Return to “Show Case Gallery”
