Aldi today
- Timllfixit
- Has thanked: 146 times
- Been thanked: 209 times
Re: Aldi today
Thanks Dickie,
I might pop in for one of those multi tool things(+ blades). As it will probably only get occasional use I bet it will be fine. The blades look as though they are the same as commonly available ones.
- Has thanked: 109 times
- Been thanked: 1038 times
Re: Aldi today
I have one of the Aldi multitools, bit noisier than other brands I have seen but does the job very nicely and the price is right for the amount of times I need it. Accessories do indeed fit other makes and the aldi ones are very good quality for the money.
- Timllfixit
Re: Aldi today
Hi all,
I was passing my local Aldi today, and managed to persuade SWMBO that I needed one of those multi tools for an up and coming job.
It comes in a blown plastic case, and the actual thing it's self feels quite heavy and solid, with the on off and speed controls that would seem as though they could be operated by someone wearing gloves.
The 23 piece accessory kit includes 18 pieces of sandpaper(!) but you do get a "half moon" blade, wood and metal blade, scraper head and sanding attachments, so enough for many jobs right out of the box.
The drive shaft has flats so a spanner can be used to prevent the shaft turning when the blade securing screw is tightened,(allen key supplied) but it was a shame that that no spanner was supplied.
I think it's quite quiet,when running off load, but haven't compared it to other makes, and does not vibrate unduly even with the largest blade.
The machine is fitted with a generous length of good quality flex, terminated with a nice nylon plug, which unlike an awful number of things these days does actually fit inside the case.
The instruction book wasn't too bad, being written in good English and is surprisingly comprehensive, although tends to tell you what you mustn't do with the tool, rather than what you can use it for.
I also purchased one of the blade packs also on sale, as It's first job will be removing grout from between some floor tiles, a job which I would think the machine would be easily capable of. I won't know how it performs until I do the job in half term, and as they might not be on sale by the time I get to reviewing it, I'll try to have a little play with it tomorrow. It seems eminently suitable for DIY, and comes with a 3 year warranty.
The blades do appear to be compatible with other makes(and vice versa) -although I haven't actually done a physical comparison- and I have thought of about twenty uses for it already, so well worth a punt IMHO.
- These users thanked the author Timllfixit for the post (total 4):
- big-all • kellys_eye • nick200 • Dickie
- Rating: 28.57%
- big-all
- Pro Carpenter
- Has thanked: 736 times
- Been thanked: 2341 times
Re: Aldi today
thanks for taking the time for a very comprehensive and usefull review
- Has thanked: 25 times
- Been thanked: 116 times
Re: Aldi today
Thanks for the review.
I'm guessing the spanner isn't required as the shaft doesn't actually rotate anyway. I'm not sure if having the spanner would allow you to tighten the blade screw without putting strain on the mechanism, but I've not found it an issue with my Bosch version.
I am not a pro.
- BillyGoat
- Troll Headbutter
- Has thanked: 386 times
- Been thanked: 796 times
Re: Aldi today
Nads!!!!!
Completely forgot about these offers. I wanted the multitool accessories. Tool 14 quid (on the B&Q clearance), accessories.....TWENTY QUID!!!!
Where do you lot get them from? Might pick up one of each pack if they still have any left.
BG
BG
- Has thanked: 104 times
- Been thanked: 490 times
Re: Aldi today
If you want blades then these are excellent, and 10 for £30 is a bargain.
http://www.rutlands.co.uk/sp+japanese-f ... e+M_DK4009
- Retired
- Has thanked: 2019 times
- Been thanked: 588 times
Re: Aldi today
I can highly recommend Aldi work trousers at £8.99 pair; I bought a couple of pairs ages ago on a recommendation from a friend expecting to wear them in the garage but they are too good and ever so comfortable; I've now got five pair. I'm now wearing my jeans out for rough work.
I've used an Aldi electric chainsaw and was surprised by how good it was with plenty of power but the one I borrowed had a very short mains lead which had it been mine I would have installed a much longer lead.
Years ago Bron bought me an Aldi detail sander the type having the triangular abrasive pads and this has already earned its keep. Aldi have some decent stuff for the DIYer.
I replaced our double glazing sealed units this year but didn't want to skimp on this job already saving a bundle doing the work myself so I treated myself to a Fein Multi-top which will last me forever.
http://www.fein-uk.co.uk/en_uk/multimas ... wwod6rAANw
Kind regards, Col.
Kind regards, Col.
- Timllfixit
Re: Aldi today
I agree about the work trousers. I too have a pair( the ones with the "hammer" pocket on the right leg), and have lasted well. They are a little frayed around the bottoms of the legs, but only because they rub on the ground when I walk.
- Chop
- Has thanked: 304 times
- Been thanked: 219 times
Re: Aldi today
I know a bloke with knuckles like that.Timllfixit wrote: They are a little frayed around the bottoms of the legs, but only because they rub on the ground when I walk.
- Timllfixit
Re: Aldi today
You shuld have seen the post before I edited it.
It said
"They are a little frayed around the bottom, but only because they rub on the ground when I walk............................
- These users thanked the author Timllfixit for the post:
- Chop
- Has thanked: 893 times
- Been thanked: 729 times
Re: Aldi today
Well, it's always great getting everyone's reviews & comments.
Thanks all for taking the time & please keep your eyes peeled for the bargains. If you're like me I hate it if I miss one & waiting for it coming around again.....
Time-served Plumber/Heating Engineer & general wind-up merchant.
The Plumbers Anthem
If you have found my help or tips useful please donate here. Thank You;
Gas Safe RGI
Scottish, British & Proud.
I'm not or never claimed to be Chris Williams.
The Plumbers Anthem
Gas Safe RGI
Re: Aldi today
I see Lidl have their Dremel style rotary tool next week.
PARKSIDE Modelling & Engraving Rotary Tool Set £16.99
I might get one of those, I've no specific job for one, but I'm sure once I have it I'll think of a use for it.
Anybody used these before?
I am not a pro.
- kellys_eye
- Has thanked: 357 times
- Been thanked: 1790 times
Re: Aldi today
I've got THREE - not Aldi versions but generically the same thing. Two were gifts from people that 'knew me' and one I bought myself. They have their uses I suppose but if I wasn't making my own printed circuit boards it would probably sit in the toolbox for 11.99 months of the year.
So, as far as my tool fetish is concerned, if it comes out for one hour, once a year, then I BUY IT.
- Cannyfixit
- Has thanked: 102 times
- Been thanked: 183 times
Re: Aldi today
I bought the Aldi Multitool back in 2011 and its still working fine,albiet it only gets used 2-3 times a year,still using the same blades that came with it too
bosch-pmf-180-v-aldi-multitool-t49764.html
