Void between concrete lintels
Diy disaster stories in this forum please, Tradesmen disaster stories are also welcome in here!
Rickrick
Has thanked: 1 time
Post by Rickrick »
I had some builders in who cut a window out for me, they have used a Concrete Lintel and put plasterboard and skimmed it over. I am now putting up a blind and looked at photos before the plasterboard went on that there is a huge void between the two lintels. Ideally, I don't want to take it down and start again so I am just wondering if there is something that I can squirt in (like they do when you have cavity wall insulation) that will fill this void and also take the strength to fix a blind upon it? Or any other suggestions would be greatly appreciated. Thank you in advance
OchAye
Has thanked: 855 times
Been thanked: 994 times
Post by OchAye »
:welcomeuhm:
Rickrick wrote: Thu Feb 27, 2020 12:53 pm there is a huge void between the two lintels
What two lintels? You said a new window opening was made and a (one) lintel was fitted. Where is the void? If you have photos post them please.
Rickrick
Has thanked: 1 time
Post by Rickrick »
This is the photo before the plasterboard and the skim having installed the window
darrenba
Has thanked: 104 times
Been thanked: 490 times
Post by darrenba »
What is that white stuff above the lintel? I hope it's not expanding foam. Have they installed a cavity tray?
cotswold builders
Has thanked: 216 times
Been thanked: 1070 times
Post by cotswold builders »
Should be a catnic type lintel with cavity tray, packed tight with sand/cement/packers and not foam.
It needs coming out and doing properly
These users thanked the author cotswold builders for the post:
Rickrick (Sun Mar 01, 2020 5:10 pm)
Return to “DIY Disasters”
