We've got a 1920's house with solid, rendered, brick walls. Over the years of past owners it's had a few issues and patch-ups. Dodgy UPVC windows fitted 30+ years ago, extensions built, chimney breasts half-removed. Things like that. We've been in it 18 months or thereabouts and have fixed a pile of damp-related problems, mainly coming down to things like badly sealed frames, poor airflow, chimneys without vents etc... and there's only maybe 1 or 2 left to sort out. One of them has me stumped as to where to start looking as I don't want to leave a trail of destruction hunting this down!
The problem damp patch lies to the side of a window in a first floor bedroom on a gable wall.
Things we do know:
* There's no external guttering
* The slate roof is in good condition (my trusted roofer has been up to take a look above the window area) and although there is no underfelt and long-term we plan on replacing it, we don't believe it to be leaking
* The outside of the house was re-painted last year with all visible cracks filled and looks to be holding up well - one crack is showing signs of starting again, but it's down to the bottom left of the window and I don't see that causing damp 2/3 of the way up.
* The silicone sealant around the window frame is in great condition and was largely replaced with Tec-7 by the painters as well. I've had a good poke around and there's nothing notable
* I replaced the silicone sealant and trims on the inside of the window frame as well
* Condensation is pretty well controlled in the building - Nuaire Drimaster fitted last year just to keep this in check but windows barely got any condensation beforehand and now, none. Windows are usually left on the vent position.
* There *may* have been sash boxes at some stage as the plaster changes, presumably from lime to gypsum around 6" or so in from the reveal in line with some of the damp.
The damp meter is showing around 10% to the right of the patches, up to about 25% max on the damp areas. Above the damp areas (i.e. top third of the frame) the damp levels are back down to under 10% and similar to the left hand side of the damp it tails off, making me think it's not coming from above.
I've tried taping clingfilm to the wall to see if it gathered moisture but after a week it didn't seem to have picked anything up, inside or outside.
We re-decorated the room 6 months ago after the cracks were filled and I used an alkali-resist primer on the area as it had obvious salts. This has started to push outwards from behind, along with a few fresh salts, again making me think it's not condensation.
I'm at a bit of a loss as to where it's from. My next thoughts are to hack away the plaster on the left of the frame and take a look in, but that's also my last-resort option as I don't want to do this unnecessarily if there's anyone has any idea what else I could be looking at?
Any advice appreciated. Even a few wild guesses might get the cogs turning and lead to a fix.
(Outside shot for completeness, I can take more of course if anybody wants to see)
