Cracking Plaster/Bubbling Paint. Pipe Issues?
otronics
Has thanked: 6 times
Been thanked: 1 time
Post by otronics »
Hello.
I have a property where plaster is cracking and paint bubbling.
This has been a problem for years but seems to have got worse.
I've taken all the broken plaster out and checked the pipes.
There are no leaks and no leak from the roof above onto the wall.
Any idea of the cause?
They are flow and return pipes for radiators. These were (poorly) fitted decades back and are not recessed in the wall enough. Is heat the issue?
Has thanked: 829 times
Been thanked: 3603 times
I suspect it is the expansion and contraction causing the breakout especially with that left hand turn. Is there any way to rerun this section, it looks like you have a fair bit of making good to do?. One way is to make some ducting to cover the pipes to stop their expansion and contraction popping the plaster. Something like this maybe? https://www.wickes.co.uk/Wickes-Double- ... &gclsrc=ds
Never done this, so hang on for the other guys to comment :thumbright:
toolbox
Has thanked: 129 times
Been thanked: 217 times
Post by toolbox »
As DWD says or if you can get a skim over it use this it's what is often used to stop this.
https://www.wickes.co.uk/Wickes-Felt-Pi ... 3/p/210456
wes56
Been thanked: 187 times
Post by wes56 »
obtronics do you still want help.
otronics
Post by otronics »
wes56 wrote: Sat Apr 04, 2020 10:08 pm obtronics do you still want help.
It's clear I need to cover these pipes and replaster.
Thanks for the help all.
wes56
Post by wes56 »
i take it thats a no.
otronics
Post by otronics »
wes56 wrote: Mon Apr 06, 2020 7:15 pm i take it thats a no.
I've not done the repair yet but no more help is required thanks (unless you have something to add...)
