help planning shower build
Hello all,
I am soon going to be fitting our a new shower room in my house, first time so i have a few questions.
The room is currently a new build bare plaster shell, it measures 104cm wide where the shower is going.
I have bought a shower tray and sliding door that are 1000 x 700 size.
As my room is 4cm wider than i need it to be I am trying to work out my best options for making the shower booth 4cm slimmer. how would you experienced chaps go about this?
- Has thanked: 250 times
- Been thanked: 212 times
I assume you'll be tiling the enclosure?
How thick are the tiles?
40mm is a fair whack to take up with tiles and adhesive though and perhaps a little more fore thought would have solved the problem.
You could overboard one end to reduce the gap to something more manageable or just dot and dab tiles on both ends with a thick adhesive bed.
Hello,
yes I am going to be tiling, the original plans were for a quadrant shower which have now changed to a sliding door rectangle, hence the size issues.
The tiles will be a standard b&Q so i presume 5 or 6 mm thick,
Yes i am thinking over boarding is a route forward, or building out somehow.
Alternatively I could put in some 2 x 1 timber at either side of the shower screen, that would leave a gap on each side of the tray to be filled. Possibly with mortar, then a tile cut for top.
For ease i am thinking about building out just one side with some 2x4 laid flat and then over boarding it, this would be maybe 60mm thick which brings the gap in the 98cm.
As a side question would you have tiles behind the screen door or do you fit the door first? Presuming the tiles run behind.
- ayjay
- Has thanked: 458 times
- Been thanked: 1708 times
On all the shower cubicles/screens or whatever that I've fitted , the instructions have always said that you should tile to the edge of the shower tray and the bits that are screwed to the walls go over the tiles with silicone behind them between the frame and the tiles.
- Has thanked: 818 times
- Been thanked: 3514 times
This needs careful planning to get the sizing right. This is making an allowance for all the levels board, adhesive and tile.The enclosure frames generally have a little bit of movement in them so check the fitting instructions on yours. In my minds eye of the job I would think building a wall out to accommodate a built in shower valve would be a good solution. But it will need exact measurement. Use Aquapanel or the like for the board.
yes i see it like this, (I think),
Its currently 1040mm wide
So if tiles and adhesive is say 10mm that's 20mm for both sides, tiles go on top of the shower tray - no problem.
So if I screwed an additional sheet of board at 20mm thickness to both sides this would bring me in to the required width of 1000mm for the tray. The tray is a confirmed 1000mm wide.
I saw this stuff at b&q, 20mm thick Q Panel,
So if I screwed that to the wall on both sides it would bring in my width to what I need.
Any objections?
One question I have is with the end of the board, the 20mm part, that will go behind the sliding door, I will need to finish this somehow and make it look decent. Any ideas?
Any objections?
- ayjay
I'm finding your terminology/workings confusing. If the frame is 1000mm you need an opening of about 1005mm assuming that both walls are plumb.
I'd suggest that you make a scale drawing to see exactly what goes where.
If there's 20mm behind the frame, any gap on the front edge can be disguised with a cover strip.
UPVC strip is always handy to silicone stick on. See https://www.directplastics.com/upvc-tri ... ndow-trims
The sliding door I have bought says it has 20mm each slide of adjustment possible - its 960mm - 1000mm. My walls are plumb square, but I have some grace space for those tiles to go behind the sliding door frame.ayjay wrote: ↑Wed Mar 18, 2020 10:47 am I'm finding your terminology/workings confusing. If the frame is 1000mm you need an opening of about 1005mm assuming that both walls are plumb.
- wine~o
- Has thanked: 1414 times
- Been thanked: 4019 times
Silicon should only be applied to the external side of the shower frame to allow any water ingress to drain back into the tray
- ayjay
That definitely applies to the bottom rail, but not the uprights.
- wine~o
I've only fitted a hundred or so shower screens or doors/cubicles in the last 12 ish years, not one of the MI's stated that any silicone should be applied anywhere other than externally. But I respect your opinion, even if it is wrong.
- ayjay
It's probably further back than that (12 years) since I last fitted one, but I can absolutely guarantee you that it was common with instructions then to silicone behind the uprights. I can even remember bo*****ing an apprentice cos he'd done inside the bottom rail as well and I showed him on the instructions where he should and shouldn't have used silicone. So, possibly my opinion is out of date, but never wrong, (an opinion can't be wrong, imo).
