I,ve just installed a new bath into an area which has been Aqua panelled ready for tiling. I intend to tile down to the bath and seal with a fine bead of silicone.
Before I fix the bath to the Aquapanel I thought I would splurge silicone around the contact area and then screw to the wall as the current gap is about 4mm. Is this a good idea, I'm thinking long term ie. will mould on this hidden silicone bead transfer to the second bead sealing the tile to the bath surround?
Sealing in new bath
- big-all
- Pro Carpenter
- Has thanked: 735 times
- Been thanked: 2340 times
