Are these switches still available?
Rorschach
Has thanked: 109 times
Been thanked: 1038 times
Post by Rorschach »
It's a 2 way switch used on a landing, as you can see there isn't room for a standard switch.
ayjay
Has thanked: 458 times
Been thanked: 1708 times
Post by ayjay »
I think they're known as Architrave switches (if that helps a search).
Rorschach
Post by Rorschach »
Ah yes that does help. I had no idea what to search for, amazing how easy it is when you have the right search term!
camallison
Has thanked: 127 times
Been thanked: 108 times
Post by camallison »
I saw some in the Screwfix catalogue I think. Worth a look.
Colin
Has thanked: 823 times
Been thanked: 3560 times
Oh yes, I had to look, but I am sure R has found them already https://www.screwfix.com/p/crabtree-ins ... hite/271hv :thumbright:
Rorschach
Post by Rorschach »
Ooof screwfix are pricey!
We are hoping that the old one will come up ok when cleaned, need to get the awful labels off etc. Before potentially making the problem worse though I wanted to check I could buy a replacement if needed.
Ebay came up as best price with postage etc. £4 delivered. They are only £2 on an electrical retailer site but the postage is high unless you spend a minimum amount. £4 is absolutely fine though, assuming we need it.
Chippo1
Has thanked: 10 times
Been thanked: 194 times
Post by Chippo1 »
I normally take the switch or socket off, then clean using Jiff and a greenee
Then set aside in a warm place to throughly dry and refit
Bob225
Has thanked: 105 times
Been thanked: 878 times
Post by Bob225 »
beleive or not WD40 has is uses - removing glue and labels is one of them
Rorschach
Post by Rorschach »
Bob225 wrote: Sat Apr 11, 2020 11:41 am beleive or not WD40 has is uses - removing glue and labels is one of them
That was going to be my first attempt, I use it for a lot of cleaning.
Return to “Lighting”
