We had a new toilet fitted this week and the waste pipe needed adjusting. As a result, the old wast pipe is redundant but still in the wall. We therefore have a hole on the inside (which I can just fill with pollyfilla before decorating) and a hold on the outside brick wall.
Once I've removed the pipe, what is best to fill in the brick hole?
How to fill in hole in external wall
- ayjay
- Has thanked: 458 times
- Been thanked: 1708 times
If you have any matching bricks, chop out the old one (stitch drill the joint and then use a plugging chisel) and replace.
- Someone-Else
- Has thanked: 47 times
- Been thanked: 2564 times
If not a load of cement (and sand etc)
- Has thanked: 2 times
I don't unfortunately. Didn't know if there was just a simple filler to use? Should I try and fill the whole gap all the way through, or just at each end?
- Has thanked: 810 times
- Been thanked: 3500 times
You can buy a small bag of mortar mix which will give you some cement to fill the hole. You can rub some brick dust on the surface as it is setting to disguise it a bit.
