Small.amount of water under subfloor
Paulabgreen13
Post by Paulabgreen13 »
Hello we are renovating our lounge and as the joists were rotten replaying them but as we dug all the crap out of the subfloor to create ventilation and put in air rock the lower part of the floor has been filling up with what looks like rain water after 3 days of heavy downpours. What is heat to do?? We are worried about putting new flooring over such a large puddle
Paulabgreen13
Paulabgreen13 wrote: Fri Jun 19, 2020 3:20 pm Hello we are renovating our lounge and as the joists were rotten replaying them but as we dug all the crap out of the subfloor to create ventilation and put in air rock the lower part of the floor has been filling up with what looks like rain water after 3 days of heavy downpours. What is heat to do?? We are worried about putting new flooring over such a large puddle
moderator2
UHM Super Moderator
Has thanked: 155 times
Been thanked: 570 times
Post by moderator2 »
Paulabgreen13, Please don't hi-jack another thread. Please explain clearly what your issue is and someone may offer you advice.
wes56
Has thanked: 6 times
Been thanked: 187 times
Post by wes56 »
Paulagreen 13,can you take some photos of the damage and a photo showing the ground level outside the lounge?
Rorschach
Has thanked: 117 times
Been thanked: 1043 times
Post by Rorschach »
My suggestion is the same as I said in the other thread. Investigate to see if it is rising water table from rain or a ground water run off problem.
