Damp on chimney breast wall
Hi, hoping someone can help me with this problem as it’s been happening for over a year now and is driving me mad!
The chimney breast from the gas fire downstairs comes up through our first floor bedroom. About 12 months ago we noticed a leak on the bedroom wall (the chimney wall) with some water tracking down it on the internal face of the wall.
Upon investigation in the loft, we found a pool of water coming through from where the roof tiles meet the chimney. We called a roofer who fixed the flashing and the pools of water in the loft stopped. At this point we assumed the leak is fixed completely.
The Chimney breast wall in the bedroom that had gotten wet never dried out though!
Original damp patch after leak: We eventually called in a damp proofer, who chiselled off the plaster where the damp patch was (around 1m from the ceiling down), applied waterproof screeding and then replastered. At this point again we thought the problem was solved.
Water proof screeding : The problem now is that the few centimetres under the original patch (below where the screeding now is) is now showing wet patches through the plaster.
Does this mean there is still a leak somewhere? If so, it must be coming on the inside of the chimney as there is no visible water on the bedroom wall or anywhere on the bits of the chimney I can see in the loft.
I’ve also been told it could be condensation? Or is it that the damp proof guy should have chiselled more of the plaster off?
I’ve had 3 roofers look at my chimney and none of them can see a problem with it. They’ve recommended a cowling but I’m not convinced that’s the problem.
Anyone ever seen anything like this before? Any help would be massively appreciated as I’m at my wits end with this now!
Thanks in advance.
New damp patches underneath where screening was applied:
Thanks in advance.
