Water Ingress - Dry Rot
Hi All, firstly apologies for the Essay!
I've got very slight but quite constant water ingress beneath the floor of my party wall of a 1933 Semi, which has caused dry rot to the whole subfloor in my kitchen.
Took a corner of the floor up to discover a few things - a shared water main running through the wall to next door - had united utilities out and they say no leak detected on it.
But next doors floor joist is completely black and sodden and there is a very slow trickle of water seemingly from their floor joist area back towards mine.
Neighbour (tenant) says she has no obvious water leaks on her side of the wall but has had other damp and water problems with the house and there are plans a foot for a whole new roof their side but no obvious water damage on the wall/upstairs on party wall, only below.
Had Peter Cox out who could not pin point the exact source of water and their assessor could only speculate that it's coming from next door, running down their obviously sodden floor joist and into my side but couldn't be 100%.
The pictures are clear that they have completely sodden floor joist/s and evidence that mine is getting constantly re-wet and drying out. I'm 99.9% in agreement but not sure the source of this water.
He also pointed out that my rear patio has been built up too high and breached the damp course, although some attempt with a membrane has been made to seemingly stop an ingress of water here. Remedial work suggested including increasing and altering the Air Bricks to increase ventilation and creating a drainage channel of sorts by angle grinding a sufficient gap in the patio to the wall and then set down to below the damp proof course filled with say pea gravel, makes absolute perfect sense. Although I would say the air flow was good anyway despite the half covered air bricks and evidenced by constant drying out.
I can accept the damp proof has been breached (previous owners work) and I am fully prepared to alter the patio as suggested, however the ingress of water was not necessarily pinpointed as from the damp course being breached and looks more like water from next door but still not sure.
Landlord of the house next door came round and before he even looked at his side for a leak or the area where he can see his sodden floor joists from my side, put the blame squarely on the breached damp course.
His theory is that water is travelling on top of the damp course and running across my rear wall to the right and through the party wall.
He was clearly being defensive and setting out with attack as best form of defence fearing it could become a blame game - at least it felt like that.
When he finally got down and had a look he then seemed less than sure and could only say he will investigate a leak on his side but I've heard nothing yet and it's still happening.
I am more than willing to hold my hands up if it is indeed my breached damp course that has caused this but I am not so sure and don't feel he is going to be honest if he does indeed discover a leak on his side.
I just wonder how plausible his theory is and how obvious to some of you more experience dampers! what the hell might be going on?
Obviously some correlation with the weather could be sort here but I've not been able to make that obvious link yet, the water seemingly comes in whatever the weather.
The picture outside shows the party wall divide and the box shows the area where the damage is inside in the corner.
- Their side of the problem, mains water running up wall
- Their side.jpg (223.23 KiB) Viewed 3440 times
- My Side and Hole
- My Side.jpg (255.65 KiB) Viewed 3440 times
- Rear of Semi
- Rear.jpg (279.61 KiB) Viewed 3440 times
- Air brick 50% covered, membrane visible
- Air brick half covered & membrane.jpg (360.18 KiB) Viewed 3440 times
- Bitumen DPC level/bottom of air brick denoted by hand
- Hand denotes DPC.jpg (353.92 KiB) Viewed 3440 times
- Patio built up
- Patio Built Up.jpg (328.84 KiB) Viewed 3440 times
- Their black floor joist, my dryer one
- My drier Joist, Theirs soaked.jpg (313.07 KiB) Viewed 3440 times
- Water Running Down.jpg (362.58 KiB) Viewed 3440 times
