Apple press screw thread
porkbroth
Has thanked: 2 times
Post by porkbroth »
I've got an apple press with a large threaded bar in the middle. To make it faster I wanted to screw a nut down on top with an impact wrench before finishing it off by hand when it needs more power. The problem is I can't identify the thread anywhere so I can't buy a nut for it!
It could be metric or imperial because 19 mm is almost exactly 3/4 inch so I'll state both and hope that someone can help me:
Dia: 19 mm or 3/4 in
Thread pitch: 3.02 mm or 0.1189 in (8.4 tpi)
I measured ten thread pitches and averaged so it should be fairly accurate. As far as I can tell it isn't UNC, ISO coarse or Whitworth so I'm stuck!
Dave54
Has thanked: 1300 times
Been thanked: 1175 times
Post by Dave54 »
How old the machine is and which country it's from might give some idea.
Could well be a thread unique to that maker though. Coarse to give a fast action.
If you have the machinery nothing says you have to make standard threads.
Sorry, but IMHO, if it's not one of the standard threads, you're going to have a job finding a nut. Let alone if it's a "one off" thread.
Has thanked: 736 times
Been thanked: 2342 times
if you follow the thread round is it a single or multiple thread??
as in mark the thread one rotation and see if you are next to the mark or one away
Bob225
Has thanked: 105 times
Been thanked: 878 times
Post by Bob225 »
By the sounds of it, It's an 3/4-8 acme lead screw (flat valley to the pitch)
These users thanked the author Bob225 for the post (total 2):
Dave54 (Mon Sep 28, 2020 2:47 pm) • porkbroth (Tue Sep 29, 2020 8:41 am)
Rating: 14.29%
Nos
Has thanked: 3 times
Been thanked: 80 times
Post by Nos »
Why do you want it to faster, have you ever pressed apples or grapes? Speed is not the way to go, a slow press with a wait then turn it another once, wait and then keep repeating until you can no longer extract any juice from the pulp, or you could be trying to get in the Guinness book of records for the fastest extractor. :lol:
porkbroth
Post by porkbroth »
Thanks for all of your replies. It looks like this, except bigger:
GF7537_Traditional_Fruit_and_Apple_Press_(12_Litre)_with_Straining_Bag%20new-500x500[1].jpg
GF7537_Traditional_Fruit_and_Apple_Press_(12_Litre)_with_Straining_Bag%20new-500x500[1].jpg (78.76 KiB) Viewed 4103 times
The thread looks like it could be ACME 29° to me:
Bob225, I think you've got it! Thank you very much. It does look like a ACME 3/4 - 8 lead screw
big-all, it is a single thread.
Nos, we've got a few different apple trees that mature from as early as July (Beauty of Bath) to November (no idea what variety) and all in we press about 800 lb of apples every year! We were going to get a bigger press or even a hydro press but because we can rarely get more than 200 lb at a time it doesn't really seem worth it. The scratter is powered by a heavy duty SDS drill. If we can get 80% of the pressing done with the impact wrench before we both heave away on 2' bars then it's worth it to us
porkbroth
Post by porkbroth »
Here is a less blurry photo of the screw thread. It might actually be square cut instead of ASME. It's difficult to tell.
Razor
Has thanked: 483 times
Been thanked: 1251 times
Post by Razor »
Acme threads are square cut. They're the ones you find used as lead screws on lathes etc because they can take very heavy pressure
Can you get a larger nut and have it welded to the end?
These users thanked the author Razor for the post:
porkbroth (Wed Sep 30, 2020 6:59 am)
porkbroth
Post by porkbroth »
The nut has to screw down the fixed thread, rather than the other way around. I had planned to weld about 8" of tubular steel onto the nut and a socket onto the top of that. Does that seem like a reasonable idea?
