Hall Table
Chippo1
Has thanked: 10 times
Been thanked: 194 times
Hall Table
Post by Chippo1 »
Just finished this , American Cherry , finished in Tung Oil
These users thanked the author Chippo1 for the post:
Chop (Fri Oct 09, 2020 11:21 am)
Gadget
Jack Of All Trades
Has thanked: 344 times
Been thanked: 342 times
Hall Table
Post by Gadget »
Nice... :thumbleft:
By eck! ©
Has thanked: 736 times
Been thanked: 2341 times
Hall Table
thats really good well done not overdone but enought to make it both chunky and elegant at the same time with out detracting from the beauty off the timber
Chippo1
Hall Table
Post by Chippo1 »
Thanks guys , I sort of based it on an American woodworkers desk he recently made , he’s on Instagram , #woodwisperer
oz0707
Has thanked: 166 times
Been thanked: 68 times
Hall Table
Post by oz0707 »
Nice what finish did you use
Chippo1
Hall Table
Post by Chippo1 »
It’s Tung Oil
yartin
Has thanked: 145 times
Been thanked: 129 times
Hall Table
Post by yartin »
Very nice well done
Chippo1
Hall Table
Post by Chippo1 »
Duck_Tape
Has thanked: 151 times
Been thanked: 45 times
Hall Table
Post by Duck_Tape »
That looks smashing, well done. Did you buy the materials to do this or did you use old stuff you had on hand to make this. Either way its a top job. Hats off mate
I love hard work, I could watch it all day
Chippo1
Hall Table
Post by Chippo1 »
Hi Duck tape,
I did some work in a local charity shop, they wanted to pay me some thing for bits and pieces I supplied and a thankyou
So they purchased the Cherry from a local hardwood supplier for me. It cost £90 + VAT, which was just about total cost other than a Tin of oil , glue and a bit of 6mm ply for the bottom of the draws.
Has thanked: 823 times
Been thanked: 3560 times
Hall Table
Good job, well done. Looking at the legs reminded me of a taper jig I made for my table saw. I cut the taper and finished them clean on my bench jointer. I think the taper leg gives a better look on that sort of table than the usual all square construction. The only little point I would make, and this sounds petty, is that I would have made the top out of one more board to allow the bit of heartwood to be removed. But I guess that was down to the availability of the stock. I used some poplar that had an edge of heartwood in a rail on some doors I made. As it was a painted finish I did not worry about it but I should have as the door bowed about an 1" down that edge. I have avoided it ever since.
Chippo1
Hall Table
Post by Chippo1 »
DWD , I made a taper jig for my table saw which worked out a treat for making these legs.
Online there is lots of debate re Cherry and the various colours of the material and weather you should or should not use it, it’s abit like Marmite. As you suggest I didn’t have a great pile of planks to choose from , some even avoid the little pin marks ect.
I hand planned all of the timber from rough sawn, great core exercise.
Most importantly, she who must be obeyed likes it !
But thanks DWD for your comments.
Dave54
Has thanked: 1300 times
Been thanked: 1175 times
Hall Table
Post by Dave54 »
FWIW, I like the sapwood.
(Can't agree with Walt!)
Nice table as well. I like American cherry.
Hall Table
I did not mean to sound churlish, I was miffed at the problem I had with heartwood, my door was like a banana. It is always hard selecting the right boards as you only have what you have. I cut a 2" oak board down the grain once thinking I would have two nice boards as I did not have enough 1" for my job. Bloody hell as soon as I cut it the tension was released and I had two banana pieces. It is all a long pathway of 'should have known better' learning from experience.
Dave54
Hall Table
Post by Dave54 »
dewaltdisney wrote: Sat Oct 10, 2020 1:52 pm I did not mean to sound churlish, I was miffed at the problem I had with heartwood, my door was like a banana. It is always hard selecting the right boards as you only have what you have. I cut a 2" oak board down the grain once thinking I would have two nice boards as I did not have enough 1" for my job. Bloody hell as soon as I cut it the tension was released and I had two banana pieces. It is all a long pathway of 'should have known better' learning from experience.
Trouble is with a lot of the imported commercial square edged boards you get here, they're from very near the outside of the log, so the end grain runs almost side to side. Makes 'em warp like anything, and be full of tension. As I say I like the sap, so it doesn't bother me. I always used to check with clients though, and of course some timber's sapwood isn't suitable to be used. English oak for one.
Talking to various suppliers of imported timbers when you know them better, the feeling seems to be that the best stuff is kept for domestic use.
But then suppliers chase the biggest profit for themselves. I used to get beautiful quarter sawn English oak from one supplier. Wide boards, properly seasoned with beautiful figure in the grain. I could trust the guy there to select the boards for me. I paid for it mind, but that was fair enough.
All of a sudden the quality went off, "Can I speak to so and so" got, "Sorry he left" and it was French Oak I was getting. Pay for quarter sawn, and get through and through.
I found out later that the company had changed hands.
Locked
Return to “Show Case Gallery”
