security light
Posted: Thu Oct 15, 2020 3:49 pm
by fickasf___k
Hi, I have a switch in my Garage that operates a Security light out side.
My question, I want to put this switch onto a timer so that the security light comes on between certain hours, as I do not want to leave it on all the time.
I have a twin socket near to the switch on the SL, can I put a timer into one of the sockets on the wall, and then wire a 3 pin plug from the SL switch, and just place that into the front of the timer?
security light
Posted: Thu Oct 15, 2020 4:50 pm
by Someone-Else
I have no idea what you mean by "SL" but to save time, why not just put a plug on the lead for your light, put the plug into a plug in timer, and plug the plug in timer into a socket.
security light
Posted: Thu Oct 15, 2020 6:08 pm
by Scotty001
Someone-Else wrote: ↑Thu Oct 15, 2020 4:50 pm
Think it's short for security light, if it were me I'd go down the route you mention re plug and timer into he plug socket.
security light
Posted: Fri Oct 16, 2020 9:41 pm
by ericmark
Some PIR's are set by switching supply off/on, so if there is a PIR there is no sure answer, but I have a access light with a smart adaptor so I can set time for light to work, and switch it on with phone if arriving home out of normal on time.
I have every intention of doing the same with old quartz lamps, plus change to LED, I don't see them as security lights, as area being lit makes it safer for any intruder, but in the main putting a time switch on PIR controlled light works OK, but on the odd time they don't like it.
security light
Posted: Sat Oct 17, 2020 7:28 am
by Rick1963
I have used photo cells in the past which are a great solution, Toolstation part number 62528.
Richard
security light
Posted: Sat Oct 17, 2020 7:51 am
by Someone-Else
Would a photo cell be pointless, since "security lights" have one built in.
The op did say
fickasf___k wrote: ↑Thu Oct 15, 2020 3:49 pm comes on between certain hours
