There is a small vent above floor level that had been closed for a few months, room regularly used and kept warm. We have a log burner which has a flue. Could it be damaged pointing on the chimney? There might be the odd damp patch in small sections of the chimney in the loft, but hard to be sure. No leaks from the roof that we’re aware of, roof near the chimney was recently re felted.
The guttering is bad and needs replacing
If it helps it’s a semi detached and the neighbours recently removed the chimney breasts, could all the vibration damage our side? There was a lot of vibration!
Also, can the wall be saved?? We only painted at Christmas and can’t get this paper as was here when we moved in
