Underfloor water leak and now damp subfloor...
Our bungalow (built 1985) had an underfloor water leak that first presented itself in the main bedroom. All the water pipes were buried in a few inches of concrete. Insurance was called and a leak detection team moved in. They found multiple leaks throughout the house, along with black mould. Two members of the family, possibly three had health conditions that have cleared up since leaving. We suspected the mould had caused them. Most rooms were found to be ruined. The water was knocked off and industrial drying units moved in and my family moved out.
After many weeks the walls were tested and found to have dried. The surface concrete was dry but the subfloor still contained moisture. The drying team said that the dehumidifiers just weren’t drying it fast enough. Builders recommended just taking the concrete and subfloor up and renewing it. Insurance dragged their feet and didn’t want to, but eventually they gave the go ahead.
We decide to relocate all water pipes into the attic and then chase them down into the walls, at our own cost.
Builders then removed the concrete screed in several rooms but stopped at the subfloor and said something along the lines of - the whole bungalow was built on top a single slab, digging up the subfloor could cause structural damage to the internal partitioned walls. These are only 100mm thick thermalite blocks. Costs could then start to spiral.
At this point builder and insurance guy are put in contact with each other. They’ve together come up with a plan just to lay visqueen and a liquid waterproof membrane over the damp subfloor and then relay the concrete screed.
I understand the builder’s priority is to make money and the insurance guy’s is to save money. With this in mind I’m wondering if this the correct and sensible option, trapping the damp in the subfloor of probably a quarter of the house and just moving on?
Any advice would be great.
