Saucepan drawer cage fixings
Posted: Thu Nov 05, 2020 1:22 pm
by Verns63
So these fixings are obviously broken and need replacing. They're from an old MFI kitchen saucepan drawer; they hold a metal cage to the base of the drawer. I'd like to source replacements so I can fix the drawer... does anyone out there have any idea what they might be called and/or where I might be able to get them from?
Posted: Thu Nov 05, 2020 2:09 pm
by dewaltdisney
Would a plastic cable grip clip do it?
Posted: Thu Nov 05, 2020 3:41 pm
by Dave54
Several plastic washers stacked together?
Posted: Thu Nov 05, 2020 4:38 pm
by ayjay
Are they the base fittings for Pan Drawer Rails? (they look familiar, without me venturing out to the garage to check)
pan drawer rails.jpg (48.44 KiB) Viewed 3187 times
Posted: Thu Nov 05, 2020 7:23 pm
by Bob225
Is it a pull out rack and the door mounts to the front ?
eg. https://www.rejsltd.co.uk/product/pull- ... ant-multi/
Only thing that springs to mind is metal p-clips
Posted: Thu Nov 05, 2020 7:55 pm
by Bob225
What size are the basket rods ? Something like a closed terry clip may work
Better idea - Cable tie eyelet and a cable tie
EG. https://www.ebay.co.uk/itm/Cable-Tie-Ey ... SwPEFbpjcs
Posted: Fri Nov 06, 2020 9:31 am
by Verns63
They're for fixing a "cage" to the base of the drawer, ayjay... I think I'm going to try some cable ties with some cable tie bases instead of the fixings to see if they work. Frustratingly I just can't find the actual item anywhere...
Appreciate your reply. :-)
Posted: Fri Nov 06, 2020 9:33 am
by Verns63
Bob225 wrote: Thu Nov 05, 2020 7:23 pm Is it a pull out rack and the door mounts to the front ?
Yes, Bob225. The drawer front goes onto the open end of this photo... I'm going to try some cable ties and cable tie bases... thanks for your reply.
Posted: Fri Nov 06, 2020 9:40 am
by dewaltdisney
