Lamp wattage
liloustick
Lamp wattage
Post by liloustick »
Hi everyone,
I recently bought a lamp and am confused by the wattage label (see image). It reads:
Max 4W for LED; Max 8W for CFL, Max 18W for Halogen. On the website it also says Max 25W for incandescent bulb.
I thought that lamps only had one Watt rating and that it applied to any type of light bulb.... Therefore if I'm correct, could I not use a LED of up to 25W? (In practice I would use a LED of around 10W as that provides sufficient lumens).
I am hoping that the Watt numbers for LED, CFL and Halogen are shown because they would provide the lumens equivalent of a 25W incandescent bulb, rather than because bulbs of higher wattage would damage the lamp.
Grateful for your help explaining the label!
Best wishes
Leanne
yartin
Has thanked: 145 times
Been thanked: 129 times
Lamp wattage
Post by yartin »
If it says 25W incandescent bulb, then usually you can use any bulb upto 25W. IE: 25W halogen , led.
This must be a small lamp.
Has thanked: 47 times
Been thanked: 2590 times
Lamp wattage
Usually the rating of a light fitting is such because of the heat the actual lamp gives off, so a halogen will give off more heat than an LED lamp, so why they have specified it that way round, who knows.
yartin
Lamp wattage
Post by yartin »
To add: I would stick to the label, 18W max for any bulb.
kellys_eye
Has thanked: 357 times
Been thanked: 1790 times
Lamp wattage
Post by kellys_eye »
There's no rhyme nor reason to those numbers - in fact I'd say they were 'upside down'. You could use any LED in there without issue as an 18W version would be like a searchlight......
Rorschach
Has thanked: 109 times
Been thanked: 1038 times
Lamp wattage
Post by Rorschach »
Well that's weird!
Lamp wattage
kellys_eye wrote: Fri Nov 06, 2020 6:33 pm in fact I'd say they were 'upside down'.
I was going to say that.
As I said, the ratings are regarding how much heat the light fitting can "handle" before damage occurs, it does seem odd that they say only a low wattage LED lamp can be used, when a higher wattage halogen gives off more heat.
Return to “Lighting”
