Dimmer not working
Patch6262
Dimmer not working
Post by Patch6262 »
Good day all - first time posting
I read some posts on this forum and its appears really helpful and friendly
I was plastering my gran-kids bedroom and I inadvertently must have dislodged a couple of cables from my dimmer switch.
When I looked at the back of the switch there was 4 red cables - 3 were live (i got one of those voltage pens) and one had "no power" but it appears to "control" the light in the loft space! Fortunately, 2 lots of wires were kept in place so i am trying to figure out what i do with the other 2 wires (the one live one and the one with no power). There are 2 holes for them to go in and i have tried every combination and it won't put my light on in the bedroom.
I don't need the dimmer and could replace it with an ordinary switch - is there a particular type of switch i need to purchase and where do i put the 4 red wires in the switch.
Any response would be greatly appreciated - even if its get an Electrician in
Take care and thanks in advance
Patch
hiace_drifter
Has thanked: 29 times
Been thanked: 16 times
Dimmer not working
Post by hiace_drifter »
Hi, this won't answer your question, but i found these guys' videos very handy, such as this one which looks at switches/lights...
https://www.youtube.com/watch?v=fixa_1jp55c
Patch6262
Dimmer not working
Post by Patch6262 »
Cheers Hiace - i will look through the video - thanks Patch
Has thanked: 47 times
Been thanked: 2590 times
Dimmer not working
Just saying..................
Despite what most people think, there is no specific rule that says "This wire shalt go in that terminal"
Pictures would help, but it really is a case of guess work or meter the cables.
Oh, and as for a volt stick, sorry not a lot of use for testing, as you have found. It says 3 cables are live, but that is improbable, but there could be a back feed via a lamp which would give "false results" a multi meter is much better.
Return to “Lighting”
