Outside Light Wiring - Chase into Internal Wall?
Posted: Mon Nov 23, 2020 12:58 pm
Hi all
I have an outside light that comes in and drops down in some trunking (surface mounted), which also previously lead to a surface mounted fused switch (off the adjacent socket). A backbox has been added for the outside light (and the socket one extended to allow for a double).
As it stands, the wiring for the socket is chased in. The outside light though, as mentioned, isn't. So, can I chase this in up to where it goes out of the wall (as shown in the pic)? The thing is, I'd need to go into some of the brick to get some PVC conduit in.
I thought about drilling out the back of the new back box and sending a UV-protected cable up but the light only seems to support a wire entry from the back.
Help appreciated.
Help appreciated.
