Outside Light
mike_m
Outside Light
Post by mike_m »
I have an outdoor light that works from a switch inside my house.
I want to remove the existing light and replace with 3 down lights along the front of my house.
i.e. I want to split the cable so it would have 3 lights instead of 1.
Is this ok?
kellys_eye
Has thanked: 357 times
Been thanked: 1790 times
Outside Light
Post by kellys_eye »
Generally yes. Loop (extend) the cable from the existing lamp to lamp two then loop it again from lamp two to lamp three. Wiring all live to live and neutral to neutral and earth to earth as you go.
To be safe, keep the new lights wattage the SUM TOTAL of the original lamp wattage i.e. if the original lamp was 500W then the total of the three new ones shouldn't exceed 500W (say 3 off 150W). This isn't strictly necessary but would be a safe method and prevent an excess of light (there is a legal limit to the amount you can have).
These users thanked the author kellys_eye for the post:
APDIY (Thu Dec 10, 2020 12:22 pm)
Has thanked: 47 times
Been thanked: 2590 times
Outside Light
To add, if you can, run the cables inside the house (to stop the weather decaying them) or run it in black pvc conduit outside
Return to “Lighting”
