Hello
I'm an installing two led lights and a separate pir unit to side of shed to illuminate an alleyway.
I'll need to get 3 glands to pass the cabling through the corrugated tin.
However, I was planning to use 3+e for the pir, but I've been told I need double insulated cable for this and 3+e is not suitable. I don't need a tight seal on the gland for it as it is only intended for mechanical protection when going through the tin - there will be a waterproof junction box used inside shed for all the connections.
Is 3+e okay here or what cabling should I be using?
Cabling for exterior light
- Has thanked: 30 times
- Been thanked: 2 times
- Someone-Else
- Has thanked: 47 times
- Been thanked: 2590 times
3 core and earth is double insulated, so long as you use a gland with an elongated hole it should be fine.
If you are using a water resistant JB, why not mount it outside, since that is what it is for, and it will probably make life easier.
I had thought about that initially but decided it would be neater to have it all inside.Someone-Else wrote: ↑Mon Jan 04, 2021 8:54 pm 3 core and earth is double insulated, so long as you use a gland with an elongated hole it should be fine.
Is it difficult to get an elongated insert for the glands?
- Someone-Else
No, you buy the whole gland with elongated hole (Can't think of the right word)Father Ted wrote: ↑Mon Jan 04, 2021 10:56 pmIs it difficult to get an elongated insert for the glands?
- Father Ted (Tue Jan 05, 2021 5:12 pm)
- ericmark
- Has thanked: 118 times
- Been thanked: 783 times
Most cable designed for use outside is black, as it resists UV light better, I have seen flat grey cable used outside, but that does not make it right, and some where it needs to power some thing outside and round profile stuffing glands seal better than oval.
