Testing LED lights for flicker or strobe effect?
Posted: Sun Jan 10, 2021 9:48 am
I fitted some electronic switches which caused problems, one lights flashing when off, cured using a load capacitor, and two flicker, the latter was first cured by fitting one tungsten bulb in a set of 5, and then my wife ordered a new set of 5 from internet so old bulb looked like this
Could only open part of it, and sorry no photos, but there were two capacitors, one ceramic and one electrolytic, and the ceramic one was disconnected, looked as if some one missed with soldering iron, so soldered on again and tested, and it worked.
However the electrolytic capacitor was larger than could have possibly been fitting inside a package like this so that seems to answer the question why the smaller package flickered there is no smoothing capacitor.
So moving on, my daughter says our lights give her a head ache, and it seems reasonable to assume they may be flickering even if I can't see the flicker, but other than opening up a bulb, how can one work out if bulbs flicker? Camera, solar cell and meter set to frequency, although the light I repaired was a G9, the lights in living room are E14, and we use loads of E14 so maybe just a case of swapping them around. But if I can't detect flicker, I can't eliminate it. Can't buy pearl E14 tungsten bulbs any more, so no option have to be LED, I have stock of BA22d tungsten, but not E14 (SES).
So how can I test the light from a bulb? Not noticed banding on DSLR camera, but may be rooms used in lights not pulsing.
and the new one more like this however within a day one lamp stopped working, and putting other type in colour was wrong, did not really do anything for months, but out of interest thought I would see what was inside the failed bulb.Could only open part of it, and sorry no photos, but there were two capacitors, one ceramic and one electrolytic, and the ceramic one was disconnected, looked as if some one missed with soldering iron, so soldered on again and tested, and it worked.
