Brass Refurbishment
Locked
nigpay1
Has thanked: 5 times
Brass Refurbishment
Post by nigpay1 »
We have some brass window fittings that before we moved in have been damaged due to condensation.
Is there a relatively cheap way to repair them or is the brass now beyond repairing?
thanks
Nigel
Has thanked: 740 times
Been thanked: 2355 times
Brass Refurbishment
heeelllooo and welcome nigpay 1 :welcome: :welcome: :welcome:
you have cast probably alloy or steel with a brassed finish
the rust is probably from the screws probably engrained beyond hope in my opinion but let others comment :lol:
nigpay1 (Mon Jan 11, 2021 11:03 am)
Dave54
Has thanked: 1300 times
Been thanked: 1175 times
Brass Refurbishment
Post by Dave54 »
What does it look like if you scratch the back somewhere?
The way to polish them is to remove the damage, and then use progressively finer abrasives before polishing. These are going to need a lot of work.
TBH though, even if they're brass, and there's enough material there to re-polish them, I'd replace if at all possible.
These users thanked the author Dave54 for the post:
nigpay1 (Mon Jan 11, 2021 4:16 pm)
Has thanked: 831 times
Been thanked: 3627 times
Brass Refurbishment
Chuck 'em. Look on Ebay for brass window fittings, you can get them for £6'ish
These users thanked the author dewaltdisney for the post (total 2):
Dave54 (Mon Jan 11, 2021 12:06 pm) • nigpay1 (Mon Jan 11, 2021 4:16 pm)
Rating: 14.29%
OnlineOnline
yartin
Has thanked: 145 times
Been thanked: 129 times
Brass Refurbishment
Post by yartin »
You can salvage but no guarantee, if it's worth it?!
Sand with 40 grit and metal brush, get rid of rust and brass colour as much as you can. Followed by metal primer spray then brass colour spray and good luck. You need primer even if paint says you don't.
PS. Why not update all with polished chrome fittings.
These users thanked the author yartin for the post:
Grendel
Has thanked: 201 times
Been thanked: 522 times
Brass Refurbishment
Post by Grendel »
I've been cleaning up an old brass blowlamp . A brass wire brush worked well and after that i have been using fine wire wool dipped in brasso. Quite time consuming. If you have a bench grinder with a polishing mop it could speed up the process. It may be an idea to spray the finished items with clear laquuer or varnish .
Has thanked: 48 times
Been thanked: 2604 times
Brass Refurbishment
I thought brass does not rust? they look rusty, which implies what big-all said is the case. You can get them on line (try "window doctor") or a local DG company
Grendel
Brass Refurbishment
Post by Grendel »
I did wonder whether it's just the rust off the fixing screws , the rest of the "rust" looks to be more like the verdigre that i've seen on other brass objects. Either way certainly quicker to replace.
Cannyfixit
Has thanked: 102 times
Been thanked: 183 times
Brass Refurbishment
Post by Cannyfixit »
They ain’t brass just brass lacquer coated they might as well be scraped
Locked
