Mantlepiece lights
Seanbond10
Mantlepiece lights
Post by Seanbond10 »
Hi there everyone just looking for some advice and bounce a few ideas around.
Im looking at fitting an oak beam above my fire place - let's be clear it will be an electric log burner type (the sort you see in b n m s for 60-100 quid) so it's not raging fire nor will it placed directly under the beam.
The beam will sit on 2 stud work/plaster board false pillers. We are looking at either a 6x6 beam or an 8x4
So I hope that sets the picture of what I'm going for now on to the lights. I want to put 2 small down lights into the beam it's self to highlight the fireplace.
I've seen this kit
fireplacefactoryoutlet/product/diy-downlight-assembly-ki
Will something like this work if I cut 4 holes into the one from the bottom to push the light into then a second to feed the cable out into a chanel then house the transformer into one of the pillers?
My main concern would be the tangs on the lights not extending out as in there suppose to slot into something 12mm thick and pop out like a plasterboard rawl plug.
Anyone have any ideas or a better solution to it
Hope you all understand and can help
Cheers sean
kellys_eye
Has thanked: 357 times
Been thanked: 1790 times
Mantlepiece lights
Post by kellys_eye »
I'd recommend you cut a 'channel' under the mantle and set an LED strip light into it. Fewer issues with heat, easier to hide, easier to service/replace.
Has thanked: 823 times
Been thanked: 3560 times
Mantlepiece lights
I was going to suggest that too. Much easier to cut a housing with a router if you have access to one. If not you could do it with a circular saw running a few cuts parallel to each other to the desired width. You can then chip out the waste easier with a chisel to clean the trench. Oak is tough so use sharp tools.
Seanbond10
Mantlepiece lights
Any links to one most I've seen are at least a metre with my chimney breast being 4ft in total so I'm going for 1ft wide pillars so I'd need some thing like 1 ft to 2ft long
I have a router never used it yet helped my mate use one on kitchen work tops so I kind of know what I'm doing
Mantlepiece lights
The trick with the router is to do a number of passes dropping the depth on each pass to gradually rout the trench. The LED light set I have linked to at Screwfix is £25 and is 8mm wide. So a 10mm trench will be best. Use a sharp cutter listen to the router as the skill is the feed rate so do not rush along. https://www.screwfix.com/p/bendable-led ... -10w/959fx
I am sure you will cope.
Seanbond10
Mantlepiece lights
Cheers will pick one up when I'm next in screw fix.
And thank thanks for the advice with the router how Mms down do you reckon I should go
Mantlepiece lights
Too deep and you will shade it into a slot like pattern of light I would think. I think that just deep enough to set it flush with the surface but I have no experience of doing anything like that. Play around by progression as you cut the channel. :thumbright:
Seanbond10
Mantlepiece lights
Sounds like a plan I'll nibble abit at a time
Do you have any experience with the screw fix light strips? How often is the cut mark
Mantlepiece lights
I am sorry, I do not know much about electrics. Perhaps post a new thread in the electrical section.
Return to “Lighting”
