Oregon Blade v Brambles
- Has thanked: 829 times
- Been thanked: 3607 times
I have quite a lot of blackberry thickets that have developed over years on my land through me taking my eye off. Farmers are not allowed to 'hedge cut' after March the 1st until the 1st September with tractor flails due to DEFRA rules to protect nesting birds. This actually made it too difficult due to wet ground conditions and a window of opportunity for a local farmer to get in and do it. I had been slowly doing clearance with a basic brushcutter and my hedge clippers but it still left a lot of waste that had to be put through a shredder.
I found a new mulching brushcutter blade called the Oregon mulching blade and I was impressed with the performance that tears through and mulches the brambles. I bought a blade and tried it on my 27cc brush cutter, it worked for ten minutes, and then the shaft broke through fatigue and buggered it. I realised that you need a decent machine with a powerful motor, a steel driveshaft, and anti-vibration. At least 50cc is needed and I have both the two and the three toothed blades. The three-toothed blade seems best.
I investigated a lot of machines and came across Wooly's video. https://www.youtube.com/watch?v=opXpgFNfqvM&t=634s I managed to get hold of the same Hyundai brush cutter, it must have been the last in the country, and I am now starting to make inroads into my thickets. It is a heavy bit of kit and being an old git and even with the harness, I get tired fairly quickly but you can clear 20 square meters in half an hour so I am doing it a bit at a time. (wind the video back it starts too late)
I am posting this in case it helps someone who has the same problem, the Oregon blade is wonderful but there is no guidance on the machine required. Even Oregon were useless when I emailed them for guidance. I did not want to fork out for a Stihl and other machine suppliers were reluctant to endorse their machine for use with an Oregon blade as it such a beast. So the guidance is as above, 50cc or greater, steel shaft rather than ally and antivibration.
- kellys_eye (Tue Mar 23, 2021 11:20 am)
