Fitting a b&q fan
Al71
Fitting a b&q fan
Post by Al71 »
Hello, I have a ceiling fan to install, mostly should be ok, but it's what to do with the loop? Where do I put them in the fan block? Can you connect them together to by pass the fan assembly although?
There are earth's but I have to strip back the insulation to get to them.
Thanks.
Has thanked: 47 times
Been thanked: 2590 times
Fitting a b&q fan
I can't see all of you fan, so I am wondering how will you see? I am assuming (Because I can't see the whole fan) you are taking a light down and putting up a fan?
Assuming that the light is going.
Almost all mains ceiling or wall mounted fixtures do not have enough space or connectors to connect the existing wires into. Therefor the easiest solution is to replace what ever you have be it ceiling rose, small junction box etc with WAGO connectors and a WAGO box and run a short cable from this new junction to what ever you are installing. That way you only have one cable to connect to your new purchase (Fan in this case)
Al71
Fitting a b&q fan
Post by Al71 »
All sorted now.
Return to “Lighting”
