What sort of shank is this?
Crey Guy
Has thanked: 2 times
Post by Crey Guy »
Hi all,
Feel like bit of a rookie question, but I bought this step drill bit from Screwfix thinking it was a normal hex shank. It has three flat sides but the rest is circular if the images don't show that.
It fits in my drill fine obviously but I need ~150mm extension. I've got this for a hex bit, but this doesn't fit that.
What is this type of shank? Google has been useless so far. Additionally, what sort of extension or adapter could I use to be able to use this?
Dave54
Has thanked: 1300 times
Been thanked: 1175 times
Post by Dave54 »
This looks like one of those shanks with 3 flats 120 degrees apart.
It gives the normal drill chuck a way of holding the bit so it won't rotate. You engage the jaws of the chuck on the flats,
These users thanked the author Dave54 for the post:
Crey Guy (Fri Apr 02, 2021 6:46 pm)
etaf
Has thanked: 38 times
Been thanked: 154 times
Post by etaf »
you could take back and get these from toolstation,if they give the size range you are after
https://www.toolstation.com/hss-titaniu ... hMQAvD_BwE
If you already have an extension have a 150mm extension that works with that type of fitting
These users thanked the author etaf for the post (total 2):
Dave54 (Fri Apr 02, 2021 11:07 am) • Crey Guy (Fri Apr 02, 2021 6:47 pm)
Rating: 14.29%
Simple DIYer
Wayne
Dave54
Post by Dave54 »
That's the best idea that etaf has above.
I hadn't read about needing an extension. :oops:
Return to “Tool Talk”
