Bell Syphon Toilet Cistern
Chippo1
Has thanked: 10 times
Been thanked: 194 times
Post by Chippo1 »
Was asked by a local charity if I could look at this toilet in a small outbuilding to the rear of a courtyard to rear of the shop. The intention is to serve tea and coffee offering seats n tables in the courtyard.
Plumber already looked and condemned it , he had filled the cistern, the ball valve was kaput , and it would not flush.
So had a look , few taps with a small hammer freed the mechanism , and bingo it flushed 2 gallons of very rusty water.
Removed the cistern , de rusted it and gave it 3 coats of Hammerite. Fitted a new ball valve , all now ready for refitting.
What a simple design , other than ball valve nothing to go wrong, big flush though so uses a lot of water.
These users thanked the author Chippo1 for the post (total 2):
ultimatehandyman (Thu May 27, 2021 7:27 pm) • oz0707 (Thu Jun 24, 2021 7:11 pm)
Rating: 14.29%
Firewatcher
Been thanked: 11 times
Post by Firewatcher »
Good for another 100 years .They made things to last in them days - love it.
Pete
Chippo1
Post by Chippo1 »
It’s fitted now and works a treat , serious flush .
The original pan looked terrible , but two minutes with a green scouring pad and it looks like new.
The flush pipe leaked at the cistern connection , but a rummage through my sack of plastic waste fittings came up with a soft rubber tapered washer of the right size , smear of silicone grease and it worked a treat , just need a new chain now .
fin
Has thanked: 32 times
Been thanked: 805 times
Post by fin »
sweet. its good resurecting olden days stuff.
Razor
Has thanked: 483 times
Been thanked: 1251 times
Post by Razor »
That looks great. I hope you are going to connect it up in lead :lol:
Chippo1
Post by Chippo1 »
Razor , I have rescued the lead over flow and reconnected it , the supply has already been run in copper by the plumber that said it wouldn’t work , so just added a isolation valve and connected it to the ball cock ! , is a ball cock PC?
These users thanked the author Chippo1 for the post:
Razor (Mon May 10, 2021 12:29 pm)
Return to “Show Case Gallery”
