How much play is normal with a Metabo FS 160 guide rail
fincainandalucia
Has thanked: 3 times
Post by fincainandalucia »
Hi everyone,
Happy to be a part of the community and look forward to learning a lot from you all.
I recently purchased a Metabo KS 55 FS plunge saw in a kit with the FS 160 guide rail for cutting. When mounting the saw on the rail, there is about 1mm of play in the saw. I was expected a nicer fit and the two screws which I believe are for adjusting for a tighter fit don't seem to make any difference. Anyone with experience who can tell me if this is normal or if I have perhaps done something wrong?
Much appreciated!
Has thanked: 739 times
Been thanked: 2351 times
if they are adjustment screws turn it over and see how they work
it may be a camb [oval wheel] so may be a part turn
fincainandalucia (Fri May 07, 2021 10:47 am)
fin
Has thanked: 32 times
Been thanked: 808 times
Post by fin »
as above thats how ya adjust the festool saws. ya want it so that there is just a slight bit of resistance but absolutely zero sideways movement
These users thanked the author fin for the post:
etaf
Has thanked: 38 times
Been thanked: 154 times
Post by etaf »
there should be 2 screws Marked as 1 in the manual - which take the play out of the saw
user manual here
https://portal.metabo-service.com/en-GB ... /00955000/
Its listed as a circular saw , rather than. plunge saw - A plunge you can put into the middle of wood and plunge straight down into the material to cut things like sink holes etc.
Not sure how well the Circular saw will plunge - although it can be done
have a look here
https://www.youtube.com/watch?v=RIz9R6Ps48E
2:51 , adjustment to the track
These users thanked the author etaf for the post:
Simple DIYer
Wayne
fincainandalucia
Thanks for your responses. In the end, it was simple oversight. I had the tool on my workbench to test it and was holding it backwards basically compared with how I would have been working with it. A little inward pressure while tightening the screw from the other side fixed up the play and allows the saw to glide over the rail. Very excited for the coming projects with this new toy!
Thanks again for your advice.
Return to “Tool Talk”
