Shared neutral?
Shared neutral?
I was changing a light fitting today, I switched off the circuit breaker for the lighting but when I touched one of the wires (not sure witch one) the power circuit switched off. I am thinking that a shared neutral could be the issue here. Can I leave it or could it be dangerous if it is a shared neutral. Obviously locating the connection could be a real nightmare. Thanks for any help.
- big-all
- Pro Carpenter
- Has thanked: 736 times
- Been thanked: 2341 times
Shared neutral?
2 way lights on stairs will be powered at one end from the apparent "wrong "circuit
was this on a stair or landing ??
- Someone-Else
- Has thanked: 47 times
- Been thanked: 2590 times
Shared neutral?
If it was off how could it switch off again?roofmonkey wrote: ↑Fri May 14, 2021 3:36 pmI switched off the circuit breaker for the lighting, the power circuit switched off.
I would guess you mean the RCD tripped? If so chances are you touched a neutral to earth, this would cause the RCD to trip, but it is nothing to worry about.
