- Ultimate Handyman Forum Index TOOL FORUM Tool Talk
- It is currently Wed Mar 12, 2025 10:00 am
Ryobi brushless angle grinder spins and stops
I have purchased used brushless angle grinder from auction. It does spin for 1-2 seconds and stops. Also if you try to start again, it just shutters but no longer spin at all, then if you spin it manually with hand a bit, and then try to start again, it will run again for two seconds.
I have tried 3 different batteries, 1.5ah, 4ah, and 5ah.
Any ideas?
Any ideas?
Mortoney
- Has thanked: 829 times
- Been thanked: 3607 times
Yes, buy a new corded one off eBay for £20.
- big-all
- Pro Carpenter
- Has thanked: 739 times
- Been thanked: 2351 times
with the battery out when you spin the blade by hand does it feel rough or smooth is the noise different to the usual rhythmic drrrrrr ??
No blade installed at the time of testing, but i can turn the part/bolt where blade attaches, yes. When i turn it i feel it segment probably because of magnets.
Mortoney
- big-all
- Pro Carpenter
because its right angle drive you have a bit off surface slip on the gears hence the rythmic noise and feel
you shouldnt have any real resistance from the magnet as the metal core has no inbuilt magnetic force but off course is metal
how was it described on i assume ebay ??
I have taken apart it earlier to see if anything physically stops it. Gear and the angle driver itself in close to new condition, pretty much no signs of use. Magnets seem to be in the motor itself because it is brushless motor, if i am not wrong
Mortoney
I will go to b and q to see how it should feel when spinning manually when new
Mortoney
- big-all
- Pro Carpenter
in dc motors its a stator [stationery bit]]and rotor[rotating bit] with the rotor being the coil and the stator being the magnet making a permanent field
with a brush less now being possible because you can now get a magnet powerful enough to push against in the small space available in a rotor you dont need brushes to transfer power to the coils on the rotor as its now a non-powered permanent magnet pushing against the power off the outer [stator]coils powered by the battery
- kellys_eye
- Has thanked: 357 times
- Been thanked: 1790 times
Post by kellys_eye »
Brushless devices require electronic control circuitry to enable them to work and as part of the circuitry there is current monitoring which stops the unit working under stall or overload conditions but, if the circuitry is dodgy, it can kick in and do as it's doing.
If the battery is under charged then a higher current flows and this can be 'seen' as a stall/overload and the protection kicks in - again.
So although brushless ones are potentially more powerful etc they have the disadvantage of added complication which, if it works correctly keeps the device and user from harm but if it goes wrong there's often little the average person can do to fix it.
The older versions, however, have a plug, wire, switch and motor (brushes) and if something goes wrong you can usually fix it - easily.
kellys_eye
