2 Gang 2 way switch problem.
Posted: Tue May 18, 2021 1:36 pm
Recently had the painters in and in their wisdom they removed the light switches and then reconnected them, since then our down stairs lights only work if the 2 gang switch by the front door is operated.
Once this first switch is operated all the others on the ground floor work.
The 2 gang has 4 red cables and 1 black, I have tested all the cables with a multi meter, only 1 red cable has 240v AC.
It is currently connected up right side, red 240v going to com, red and black t&e to l2 and l1 respectively.
Left hand side 2 reds to L1 and link com to com.
This is the first switch in the hall by the front door, it did control light by door and light at bottom of stairs.
Another 2 gang is located at the bottom of the stairs, it controls light at bottom of stairs and light on landing.
Any ideas would be greatly appreciated or is it time to call electrician?
