- Ultimate Handyman Forum Index TOOL FORUM Tool Talk
- It is currently Wed Mar 12, 2025 9:50 am
Clarke Angle Grinder not working
- Has thanked: 78 times
- Been thanked: 8 times
I have an angle grinder which does not work.
I have watched videos and there seems to be a lot of disecting and I fear I'll not get the thing back together again.
I have started with the basics. Check fuse. It had a 5amp in. I replaced it with a 13amp because the plug said 13amp.
Still not working.
I see that the brushes are easy to replace.
Will worn brushes stop a power tool working? If so, how do I tell if the brushes are worn down enough to be the problem?
Still not working.
zaffy
zaffy
- ayjay
- Has thanked: 458 times
- Been thanked: 1708 times
Yes, worn brushes will stop a tool from working, best method to tell is to compare with (or fit) a new set. There will often be excessive sparking noticeable from worn brushes. Yours do look a bit short - how old is the tool, and has it done a lot of work?
Your is showing as the size it should do for 1152 × 723 pixels. If it was much larger it wouldn't post as there is a size limit.
ayjay
Ayjay, thanks for responding so quickly. What does one call a lot of work when it comes to angle grinders? It is old, so possibly has seen a lot of work in its lifetime. But there again, it had a DIY owner and not a professional owner, who, I presume would use it far more.
Re: Photos. Thanks. I was concerned I might be taking up too much space.
zaffy
- Has thanked: 1300 times
- Been thanked: 1175 times
Dave54
Dave,
Just noticed, the other brush is even shorter. Have ordered a couple from EBay. Under £6 free P&P. Will keep Ultimate posted on my progress.
zaffy
- wine~o
- Has thanked: 1415 times
- Been thanked: 4030 times
TBH I'm surprised no-one else picked up on that.
wine~o
Wine. Yes. I should have reposted. I noticed after posting the comment that the lable on the machine said 5amp. I did change it back. Another learning curve.
Thank you.
Thank you.
zaffy
- kellys_eye
- Has thanked: 357 times
- Been thanked: 1790 times
Post by kellys_eye »
The fuse protects the CABLE, not the equipment. If the cable is 1mm core section or greater then a 13A fuse is acceptable - though not always practical. Without knowing the cable size the fuse should, of course, be as per the manufacturers recommendation.
A 5A fuse leans towards the angle grinder being 750W or less.
- zaffy (Sat May 29, 2021 1:03 pm)
kellys_eye
zaffy
zaffy
New ones have arrived.
- 20210529_110530.jpg (127.09 KiB) Viewed 1892 times
zaffy
Dave54
Dave, bringer of bad tidings. Hope the photo is an optical illusion. The advert stated to fit my model. I haven't tried them yet. I will keep you posted.
zaffy
Easy enough to compare them before trying to fit.
Don't fit them if they're narrower. They need to be a nice sliding fit in the brush boxes, but not too loose.
Won't be the first time, I've had "That's the one that fits sir" with all sorts of things, only to find that they actually fitted several different types.
Dave54
