Where do I get a big spanner from - for changing sink plug
OM2
Has thanked: 7 times
Post by OM2 »
I need to change the sink plug.
We had one changed a few years ago by builders.
They told me I needed a big spanner.
All other tools I tried didn't work.
Where do I get a big spanner from?
Sounds like a dumb question!!
I measured the width I need to hold onto - it's about 2.5 inches at least.
That's 6.5cm.
Adjustable spanners - they don't go that big.
Ones that I've seen on Screwfix cost nearly £100 for that wide!
The ones the builders used was just a fixed width.
I'd prefer something I can adjust.
Any ideas?
Thanks.
Has thanked: 48 times
Been thanked: 2604 times
Quality costs, it may not get used much but it should last a life time (Or look on ebay)
OM2 (Thu May 27, 2021 11:25 pm)
wine~o
Has thanked: 1415 times
Been thanked: 4030 times
Post by wine~o »
Has thanked: 829 times
Been thanked: 3607 times
Search ebay for '16-68MM Adjustable Convenient Large Spanner Wrench Opening Plumber Reliable Tool' £4.88. "2.5" is 63.5mm
OM2 (Thu May 27, 2021 10:32 pm)
OnlineOnline
fin
Has thanked: 32 times
Been thanked: 808 times
Post by fin »
do you mean the nut on a basin? like usually a plastic nut.
https://www.toolstation.com/1-14-basin- ... lug/p23484
like that? if so just buy a pair of adjustable pliers like these
https://www.toolstation.com/minotaur-wa ... ers/p12134
thats what i use whenever i fit a basin. well..... i use similar... but the one i have is more like £40-£45 to buy
These users thanked the author fin for the post:
Bob225
Has thanked: 105 times
Been thanked: 881 times
Post by Bob225 »
5 holes aka pump pliers are all you need (large) at a push you can use a strap wrench, if its a plastic nut you can cut it off
These users thanked the author Bob225 for the post:
OM2
Post by OM2 »
Thanks for the replies guys.
@dewaltdisney - I think this is my best choice. I'll go for that. Under £5 - that's criminal.
@fin @Bob225, those suggestions are no good. Actually been there and done that. If I had a good quality water pump pliers... maybe... the one I had was cheap pound shop stuff. Strap wrench - tried that, no joy.
Problem is that the sinks haven't been touched in 12 years say - so everything is literally welded on.
When the builder opened, he used a massive spanner. I guess he got enough grip on. I'll try the water pump pliers if the 68mm pliers don't work.
Thanks.
If you can get a purchase on the fitting you can add extra leverage by attaching an extension to the handle if you can figure something out like a tube, mole grips, or the like.
OM2 (Thu Jun 24, 2021 2:40 pm)
OnlineOnline
Return to “Tool Talk”
