Cordless drill v Cordless impact driver
leckyone
Has thanked: 7 times
Post by leckyone »
Have always used my cordless battery drill for drilling and screwing screws etc with its clutch and 2 speed.
See many diy/professionals using cordless battery impact drivers.
Whats the advantage using the impact drivers over the drill screw drivers
toolbox
Has thanked: 129 times
Been thanked: 217 times
Post by toolbox »
hey have far more punch than a normal drill but you only really need them for large/ long screws, like screwing sleepers together or decking. Too much power for your 1" number 8 screw!
Good for shifting really tight old screws too.
leckyone
Post by leckyone »
Thanks.
Got some 400 or more stainless 4mm x 40mm screws to put onto a fence is why I asked.
Has thanked: 829 times
Been thanked: 3607 times
The danger is you could tighten the screwhead right through the fence boards with an impact. An ordinary drill/drover would be better I feel.
banjerbill
Been thanked: 27 times
Post by banjerbill »
Stainless screws shear and cam out much easier than ordinary screws ,even more so with an impact driver. Advice is usually to drive an ordinary screw in first to cut a thread, This means three times the work however, screw in, screw out then replace with stainles
Bill
These users thanked the author banjerbill for the post:
Job and Knock (Sun Jun 20, 2021 9:11 am)
Grendel
Has thanked: 201 times
Been thanked: 517 times
Post by Grendel »
A little while ago i brought the dewalt twinpack , drill and impact , to replace my old 14.4 volt drill/driver that was getting towards the end of it's life. One advantage is of course the drill can have a pilot bit and the impact can have the screwdriver bit so less faffing around changing bits. The impact took a little getting used to but with the trigger control it's possible to be fairly gentle and i've even used it to put in slotted brass screws.
OnlineOnline
Graeme from Tod
Has thanked: 20 times
Been thanked: 13 times
Post by Graeme from Tod »
I have a Dewalt 887 3 speed impact driver. The lowest speed is a gentle screwdriver setting which is useful for small screws, the higher two are full bananas impact driver modes. As Banjerbill says stainless steel screws & impact drivers don't play well together.
Job and Knock
Old School Chippie
Has thanked: 742 times
Been thanked: 1573 times
Post by Job and Knock »
Unless you have a 3-speed impact driver that is
Has thanked: 739 times
Been thanked: 2351 times
as an aside
with brushless technology many many tools multi function and multi control with amazing levels off delicate control are all electronic so your 887 impact has no gears but is given 3 separate levels off performance chosen by an electronic position switch rather than gearing
https://service.dewalt.co.uk/DEWALT/GB/ ... ctId=40934#
fin
Has thanked: 32 times
Been thanked: 808 times
Post by fin »
ive got an impacter but i hardly ever get it oot.
i have 2 of the same model of dewalt xr drill. brushed motor so a bit of an older one. one with a pilot bit one with driver bit. one of them needs brushes one i replaced brushes ages ago and it looks like its gonna need a set soon like
Return to “Tool Talk”
