Replacing blown plaster
Posted: Fri May 28, 2021 6:20 pm
Hello,
I'm renovating a couple of rooms and the plaster has blown in certain areas, although most of it is sound.
Ive hacked off the problem areas and can now see why it's blown. There is a wooden beam between the brick work which over the years has obviously led to the plaster failing. The house is not damp and these are internal walls anyway.
Anyway, the old plaster is the original victorian lime based plaster on top of a scratch coat. I was planning on blue gritting the surface then just filling it back up with Hardwall or undercoat then skimming. Would this be sufficient/correct?
See attached pic:
See attached pic:
