ANY IDEA WHAT THIS IS AND CAUSE?
david23
Post by david23 »
Keeps appearing on walls even after wiping them down any idea what this is? and the cause tried to google and cant find anything myself
arco_iris
Has thanked: 184 times
Been thanked: 535 times
Post by arco_iris »
:welcomeuhm:
Is it the patterns we're supposed to be looking at?
It's wall paper, painted over.......
:dunno:
yartin
Has thanked: 145 times
Been thanked: 129 times
Post by yartin »
I think he means the whites
david23
Post by david23 »
yes yartin the white looks more like a faint blue chalk color in person and its appearing in all the rooms mainly the living room.....1st picture with the brown is the living room were its all over....the 3rd picture is the bedroom and u can see it on there too
yartin
Post by yartin »
Is it something new? Assuming you've been living in the house for a while
Did you paint walls recently?
david23
Post by david23 »
@yartin been living in the house a while yes and no they havent been painted recently...the landlord sent somebody round last year and claimed it was the result of using cheap paint...but its appearing upstairs too (in the third picture) on wallpaper thats had no paint on at all. the window frames are rotting and busted up so my theory was it was some sort of mould due caused by condensation in the winter the windows get really condensated. hes fixed 2 windows downstairs and hes yet to do the others as he claims he doesnt have the money to do all at once. ive looked around cant see any pictures that are like it so thats why ive come to the forums and maybe somebody can shed some light
Neelix
Has thanked: 118 times
Been thanked: 215 times
Post by Neelix »
If you’ve got condensation, you need to improve the ventilation by opening windows .....
david23
Post by david23 »
Neelix wrote: Sat Jun 05, 2021 9:59 pm If you’ve got condensation, you need to improve the ventilation by opening windows .....
yes i know that lol the problem is like i said the windows are rotted away and gaps in them...so in the winter when its -2 u have the heating on windows closed the cold air from outside gets in through the window gaps causing bad condensation....the windows are open alot when they can be but during the winter when its freezing cold its not possible...anyway the condensation isnt the issue i know why that is caused. the problem was in the pictures posted and what it was and what was causing it since i cant find anything that looks like it online.
yartin
Post by yartin »
Are the whites upstairs and downstairs on the same wall ?
david23
Post by david23 »
yartin wrote: Sat Jun 05, 2021 10:27 pm Are the whites upstairs and downstairs on the same wall ?
[/quote downstairs its on all the walls in places, upstairs it on a some of the walls but as u can see nowere near to the degree it is on the downstairs
yartin
Post by yartin »
I meant if the whites are appearing on the same side of the house?
Has thanked: 823 times
Been thanked: 3558 times
Have you checked very carefully if it is an old anaglypta wallpaper that was covered over? The pattern looks too controlled to be a naturally occurring random paint/plaster reaction I suspect it is either paper or hardened paper adhesive that was not scrubbed down when the room was repapered. Try dabbing hot water on a small test patch and see what happens.
david23
Post by david23 »
dewaltdisney wrote: Sun Jun 06, 2021 9:54 am Have you checked very carefully if it is an old anaglypta wallpaper that was covered over? The pattern looks too controlled to be a naturally occurring random paint/plaster reaction I suspect it is either paper or hardened paper adhesive that was not scrubbed down when the room was repapered. Try dabbing hot water on a small test patch and see what happens.
it washs off but would appear again eventually ive wiped it off previously, in the living room its on every wall, but in other rooms upstairs its in certain spots not as bad. i cant be a problem with wallpaper
as it appears in other rooms were its newer wallpaper and its not hardended adhesive as it started to appear long after the paper was put up. it looks like a chalky texture.
