Festoon lights - waterproof extension cable?
Zudecke
Has thanked: 28 times
Post by Zudecke »
We run some festoon lights around our garden and today finally installed a waterproof outdoor socket for them to connect to. Next problem is that the lead is no longer long enough to reach the new socket.
Luckily there's a 2-pin extension lead from the end of the lights into a mains cable lead, which I thought I would easily be able to find a longer replacement for on Amazon or the like, but not having much luck.
Does anyone know if I can find a waterproof 2 pin to mains 3pin lead in a longer length?
Ideally 2 metres?
Many thanks
Z
Has thanked: 47 times
Been thanked: 2590 times
error
Zudecke
Post by Zudecke »
Someone-Else wrote: Sun Jun 06, 2021 9:24 pm That looks like one of them "Buy these lights and when one lamp fails buy a whole new set" type of thing.
It would be easier to move the socket.
Oh god, I was hoping you wouldn't say that....!
But that said
Do these lights have a large "Lump" before the lights start?
There are several leads out there, but I wouldn't put mains through them.
Picture of your lights?
(I had some, looked nice at first, didn't last long, I changed to mains lamps)
Neelix
Has thanked: 118 times
Been thanked: 215 times
Post by Neelix »
I suspect those aren’t 230 volt lights so connecting them directly to a socket is likely to result in a loud bang
Zudecke
Post by Zudecke »
Neelix wrote: Sun Jun 06, 2021 10:03 pm I suspect those aren’t 230 volt lights so connecting them directly to a socket is likely to result in a loud bang
Sorry if I misread, but the lights do currently work fine and have done for 3 months at least since we inherited them.
There's no power pack anywhere.
Will post some more photos when I'm up later
Zudecke wrote: Mon Jun 07, 2021 1:50 amThere's no power pack anywhere.
That would depend on what you are looking for.
As I said, I had a set of LED festoon lights that ran from the mains, there was a capacative dropper* just before the lights.
If your lights have "shades/lenses/coverings" (call it as you will) can you take one off and take a picture.
* A capacative dropper (That is its technical name) changes mains to what ever voltage /current that is required, but they are very small and in the case of the lights I had, it was just a "lump" on the cable, unless you looked for it you could miss it.
Oh, please take several pictures and post the in focus ones.
Zudecke wrote: Mon Jun 07, 2021 1:50 amWill post some more photos when I'm up later
Is it later yet?
Zudecke
Post by Zudecke »
Hi guys
Our waterproof double socket and waterproof larger socket housing are both installed and the wiring to the double socket is working great.
In order to start using the bigger waterproof housing box, can I run any extension cable from the double socket to the jaeger unit?
Thanks!
Z
Zudecke wrote: Sat Jun 26, 2021 8:51 amcan I run any extension cable from the double socket to the jaeger unit?
What is one of them?
Answer is probably only when you want to use it, since most leads are not meant to be left outside 24/7
Zudecke
Post by Zudecke »
Really? Oh damn, not very convenient!
So might a solution to run it inside conduit?
You still have not said what a jaeger unit is.
Yes conduit or SWA it is. The reason being as I said that most cables are not meant to be left outside 24/7 as they will breakdown and cause problems. If you are going to use conduit it must be black as white conduit will also breakdown if used outside.
Return to “Lighting”
