This might be a very very stupid question, and it also might be difficult for me to explain since I am not a native English speaker, but I'll try my best!
I have used spirt levels to test if something like a counter or a shelf is levelled or to check if a surface is vertically levelled. However, how do I check if a surface (let's say a wall) is levelled horizontally?
To better explain my question I am attaching an image, let's pretend that this is an image of a room and you are looking it from the roof (so what you see at the center is actually the floor), as you can see the wall at the right is slightly shorter in length and is causing the wall at the bottom to not being straight.
Is it possible to use a spirit level to check that?
I mean, if you are facing that wall and put the spirit level against that vertically, yes you can check if this wall it's going inwards or outwards, but what if it's going outwards at the right or at the left?
I apologise for the stupid question
