pull out cupboard door gear
oldalbanian
Post by oldalbanian »
I have two base units with full height doors attached to a single pull out cupboard base
one of the runners that attaches to the door has rusted through
this has happened before, and I've previously bought replacement runners and door fixings online. Unfortunately i don't have a record of where they came from, and every search term I've tried has just produced larder unit gear or simple drawer runners
does anyone know where I might get them? Or even just what I should search for?
thanks
Has thanked: 814 times
Been thanked: 3508 times
oldalbanian
sadly not
the ones I want have a bracket at the front of the runner that then attaches to a matching gizmo on the door front
If all else fails I guess i could use a standard runner and fix an angle bracket to join the pull out base to the door, but the current ones are adjustable to get the door to line up perfectly
photo is upside down but I hope shows what I'm after
Grumps
Has thanked: 51 times
Been thanked: 152 times
Post by Grumps »
Have a look at Ironmongery Direct.
https://www.ironmongerydirect.co.uk/sea ... %20runners
Or even better, email them that photo and ask their opinion.
Another option is SDS London.
https://www.sdslondon.co.uk/search/?key ... er+runners
Whilst I've never purchased from them when I enquired about a sliding door runner profile they readily sent a copy of the Technical specification.
oldalbanian
Thanks. I had a look at the ironmongery direct website to no avail, but your idea of sending them the photo is a very good one, so I'll try that
London mike 61
Has thanked: 285 times
Been thanked: 402 times
Post by London mike 61 »
Try searching on google for ‘ drawer runner with drawer front bracket ‘ and click on the images tab, there are a lot of choices on there that would suit your drawers.
Mike
arco_iris
Has thanked: 184 times
Been thanked: 535 times
Post by arco_iris »
If you've previously bought "online" then you would have received email acknowledgements. Go into your email program and use the Search function for likely keywords. One clue could possibly be, what's the length? Supposing it's 450mm, then search for 448mm 449mm 450mm 451mm 452mm in turn, these items are often sold by size.
oldalbanian
image search a very good idea - thanks. There's one from hafele that isn't quite it but might well do. the problem is that pulling a full height door from the top puts a lot of torque at the bottom joint!
sadly I've changed email system since I last ordered so can't search back
kellys_eye
Has thanked: 357 times
Been thanked: 1790 times
Post by kellys_eye »
What payment did you use if purchased online? Credit card and/or Paypal records may reveal all.
wine~o
Has thanked: 1414 times
Been thanked: 4017 times
Post by wine~o »
Any markings on the old one ?
Return to “Kitchen Fitting”
