Which Sub-floor mechanical ventilation to use?
Misskerry
Post by Misskerry »
It looks as though I have to get some mechanical ventilation or under my floor, as only one outside wall. Anyone got any suggestions on what to use as not much information online?
Thanks.
Neelix
Has thanked: 118 times
Been thanked: 215 times
Post by Neelix »
Hum ........... for this to work you would need to increase the air into and out of the affected area - so can you add more airbricks or similar?
Ventilation needs a "source" of air to work.
Misskerry
Post by Misskerry »
There's quite a big airbrick at the front but the damp smell is more by the solid internal wall, so air is getting in, it's just not getting out.
