Replacing a light fitting
liamus
Has thanked: 4 times
Been thanked: 2 times
Post by liamus »
Hello. Help very much appreciated please!
I am replacing standard ceiling rose with pendant fitting. The current ceiling rose is wired as per the image. The two brown wires from the ceiling connect to the same terminal. My question is I want to wire these two a Wago connector (second image) but the two wires won't fit in the same hole. Can I put one in one hole the other in the other and the brown from my actual light to the third or must they be wired I'm same terminal. Thank you!
Has thanked: 47 times
Been thanked: 2590 times
You have a 3 terminal wago, use all 3 terminals. You are only meant to put 1 wire in each terminal. (You can also get 5 terminal wagos)
liamus
Post by liamus »
Excellent thanks for quick response. To save me some space in the fitting can I use this one then like so:
You can get
As well, smaller than the ones you have, better than the white ones.
Why not do what you should do, use which ever wago, put them in a wago box, poke the wago box up into the ceiling.
liamus
Post by liamus »
But that's what I'm doing...asking what I should do. I'd like to know if what I have is suitable?
Scotty001
Has thanked: 26 times
Been thanked: 174 times
Post by Scotty001 »
Liamus, yes what you have is suitable, as said with wago only 1 wire per terminal hole, if you have 2 brown wires coming from the ceiling and 1 wire coming from the light unit then you need a minimum 3 terminal wago, same for the blue, although the earth is in 1 sheithing it has 2 cores, if the pendant and light does not need an earth connection then you will want a minumum 2 terminal wago (but to future proof changing the pendant again in the future for One that does need an earth use a wago with a minimum of 3 terminals so you can connect an earth into it.
The white wago you picture can be harder the re use and release from the cable but they are more compact, the grey one and one that SE pictured is easier to re use as they have levers on them but take up more space.
If you put them into a wago box make sure that there is enough room push the box onto the ceiling and retrieve it at a later time when needed. The box may be bigger than the hole on the ceiling where the wires come through, or there could be an obstruction (joist) in the way.
liamus
Post by liamus »
Thanks Scotty. So the new fitting doesn't need an earth. For earths can I put both into screw cap connectors?
Scotty001
Post by Scotty001 »
So long as the earth's are joined then yes but screw cap connectors are not the best.
if you have a spare white wago just put them into that. or if you are going to bin the original ceiling rose, just take the terminal block that the earth was screwed into out of the ceiling rose and put them in that (probably the most space saving way.)
liamus
Post by liamus »
Great thank you. Will do that.
Out of interest what is the problem with screw cap connectors?
They were banned from use in the UK many years ago. The main problem is they easily go high resistance, leading to Fire.
Also they can become loose over time, giving high resistance causing Fire
The regulations have changed and most terminations must be accessible for inspection (If that is done or not is a different question.)
However wagos are what is known as "maintenance free*" ..............so wagos it is then.
*They have to be accessible with use of a tool, so they should be put in a wago box and a zip clip put on the box so you can't open it without cutting the zip clip.
arco_iris
Has thanked: 184 times
Been thanked: 535 times
Post by arco_iris »
Someone-Else wrote: Sat Aug 07, 2021 8:21 pm
Now that's interesting, didn't know that.
But, S-E, keep up - OP's wires are all solid, not requiring the lever type connectors - the latest incarnation of Wago 2273s for solid cores up to 2.5mm sq. are tiny (and brilliant).
Now they need a new smaller box!
I believe you will find that 2273 wagos came out around 2013 so they are not the latest. Lever type wagos are good for everything and easy to re use.
Return to “Lighting”
