MK LOGIC RAPID FIX
stevei
Has thanked: 86 times
Been thanked: 118 times
MK LOGIC RAPID FIX
Post by stevei »
Just been getting some stuff to fit a fused spur for an outside light to run from a double socket on a ring main when I saw the new rapid fix socket by MK. What a brilliant idea and ideal for me as I hate putting three wires in one fixing on standard sockets. Apologies to those that have already seen them.
MK LOGIC RAPID FIX.jpg (88.88 KiB) Viewed 2013 times
These users thanked the author stevei for the post (total 2):
arco_iris (Sun Aug 15, 2021 2:56 pm) • Grumps (Sun Aug 15, 2021 5:51 pm)
Rating: 14.29%
ahfix
Has thanked: 61 times
Been thanked: 184 times
MK LOGIC RAPID FIX
Post by ahfix »
Yeh came across these recently. Do they work like levered wago connectors?
stevei
MK LOGIC RAPID FIX
Post by stevei »
Yes I think so. Haven't picked it up yet.
Has thanked: 47 times
Been thanked: 2575 times
MK LOGIC RAPID FIX
They do. You also have to strip the cable 10mm, and they will fit in a 25mm back box.
kellys_eye
Has thanked: 357 times
Been thanked: 1790 times
MK LOGIC RAPID FIX
Post by kellys_eye »
£6 each at SF - not too bad, I was expecting them to be far more expensive.
stevei
MK LOGIC RAPID FIX
Post by stevei »
Yes they are similar to Wago but with a stronger feeling return spring on the connectors. Just fitted it. Really easy to use.
These users thanked the author stevei for the post:
aeromech3 (Mon Aug 16, 2021 11:32 am)
aeromech3
Has thanked: 177 times
Been thanked: 665 times
MK LOGIC RAPID FIX
Post by aeromech3 »
Failed :scratch: could not locate on SF web any clue to numbering ?
MK LOGIC RAPID FIX
aeromech3 wrote: Mon Aug 16, 2021 11:41 amFailed :scratch: could not locate on SF web any clue to numbering ?
:shock:
click here
aeromech3
MK LOGIC RAPID FIX
Post by aeromech3 »
Great S-E, shame it does not have outboard rocker switches and its not slim profile though doesn't look that thick and only 50p dearer than the earlier type # 29304.
MK LOGIC RAPID FIX
Give them time.
I never use socket switches anyway.
Grumps
Has thanked: 51 times
Been thanked: 152 times
MK LOGIC RAPID FIX
Post by Grumps »
Someone-Else wrote: Mon Aug 16, 2021 3:51 pm I never use socket switches anyway.
Socket switches. Bane of my life. I set up a scaffold tower exactly where I want it. Places all needed tools, including electrical, and an extension lead, atop and to hand.
Clamber aboard then only to discover that the socket switch has been turned off. Grrrr ::b
Edited to add that the missus, on reading the instructions for our current 15 year old toaster, noted that they included a directive that it should be switched off when not in use.
Who else would actually read the instructions for a toaster. :wtf:
aeromech3
MK LOGIC RAPID FIX
Post by aeromech3 »
Whilst I have similar experiences as Grumps, my Fathers house 1966 had no switches, my Mother would always pull the tv plug out at night, remembering a local house struck by lightning. Now, due to the emphasis on saving energy, I do wall switch off my tv, sound system, and induction hob when not in use and just recently the stupid smart view hand set; since doing an energy supply switch and still being estimated and after complaining, then cheekily being asked to take a photo of my meters, after which they said they had done a health check and have them logged now!
Oh! and in-between the operator insisted the gas smart meter had its own electrical supply and I would not run the battery down by pressing the 'read button', what a joker, later he said he was new to the job, I sympathised but then why bother the customer before doing due diligence health check first.
Sorry should not rant on, subject is my dislike for mid rocker switches is having to slide a finger in-between plugs to turn off, made even worse by some convertor plugs I have.
Neelix
Has thanked: 117 times
Been thanked: 214 times
MK LOGIC RAPID FIX
Post by Neelix »
There are ignorant sparks going around giving C2’s for sockets with no switches on EICR’s
Return to “Electric Forum UK”
