Replace external corner beads for re-skim?
Dave1978
Has thanked: 3 times
Post by Dave1978 »
I have a wall with an external corner. I plan on having the room re-skimmed if I can find a plasterer.
Will they remove the current corner bead, or just stick a new corner bead on top of the existing?
The condition of the walls is just bad enough to warrant a reskim. Quite solid though.
Thanks,
Dave.
Has thanked: 47 times
Been thanked: 2590 times
Dave1978 wrote: Thu Aug 26, 2021 4:51 pmWill they remove the current corner bead, or just stick a new corner bead on top of the existing?
Would it not depend on what you ask them to do, and the condition of the existing one?
Dave1978
Post by Dave1978 »
I presume they will need to replace it, as the existing one is under the existing skim.
I was wondering if it goes on top of, or replaces the existing one?
Dave
Peloquin-UK
Has thanked: 1 time
Been thanked: 4 times
Post by Peloquin-UK »
They'll stick a new one over the corner and skim to it.
These users thanked the author Peloquin-UK for the post:
Dave1978 (Fri Aug 27, 2021 6:18 pm)
Dave1978
Post by Dave1978 »
Peloquin-UK wrote: Fri Aug 27, 2021 6:13 pm They'll stick a new one over the corner and skim to it.
Perfect. Thanks Peloquin.
Dave.
wes56
Has thanked: 6 times
Been thanked: 187 times
Post by wes56 »
Dave1978,
Presuming you are talking about a solid plaster corner, no plaster board involved.
It could depend on whether the existing bead is damaged - or rusty from damp conditions?
The correct method might then be to remove the existing corner bead - fix a new corner bead, and fill-in & skim.
Dave1978
Post by Dave1978 »
Solid plaster. No damp. No issues really.
There are a few in the room. Around windows, one near a fireplace.
I appreciate there is no standard practice, but in this room I at least, cannot see any complications with damp etc.. I would like it re-skimmed to get rid of the wallpaper and have a nice, paintable finish.
Thanks all for your help.
Dave.
Return to “Plastering Forum”
